Brake lights stick
Old Oct 13, 2007 | 12:28 AM
sh0kk86's Avatar
Brake lights stick
every time i press the brake the lights stick on, i have to tap the pedal once or twice to get it to go off. im afraid its gonna drain my brand new battery, what should i do correct this problem.
Old Oct 13, 2007 | 12:50 AM
stormin94's Avatar
I dunno too much about electrical, but I can tell you that you probably have a switch that is going out, or something along those lines. Hope that helps at least a little.
Old Oct 13, 2007 | 03:26 AM
TORTIS's Avatar
look under your dash at the brake pedal . your switch is up by the top of the pedal. see why the pedal is not contacting the switch. might just need to adjust it.
Old Oct 13, 2007 | 04:44 AM
88-surf's Avatar
beat me to that one tortis
Old Oct 13, 2007 | 11:19 AM
n4ynu1010's Avatar
Brake Light Problem
Switch may be bad ( about to commit electro-mechanical suicide) , may need some lubricant (lubricating Momentary Switches is good for switch if you use the proper lubricant ), or switch may be loose (mounting hardware) , heck could be just a wire has fallen in the way keeping pedal arm from depressing switch or wire harness plug may be loose , probably a simple problem
ashersullivan88yota
Jan 18, 2022 05:37 PM
fountain
Dec 31, 2015 06:08 AM
Sep 4, 2015 09:27 AM
Sandman
Jul 14, 2015 12:36 PM
Johntom240
7
Jul 13, 2015 12:18 AM
