really bad knock
Old Oct 12, 2007 | 09:13 PM
just a 22re's Avatar
really bad knock
well thats about it she has a bad knock at over 2.5k and i think its the chain cause it is very very loose about an inch and a half of play shes a 22re 5 speed efi need help and its not ping even though its an inch passed the timing dohicky thingamabob any ideas on what this knock is?
Old Oct 13, 2007 | 12:06 PM
n4ynu1010's Avatar
Motor Knock
Replace the chain by all means , a chain or belt slapping would cause to me a different noise than a bearing knock , hope you don't have both , take care of the chain and go from there , if you still have the knock then I would have to say go from there , hope its not a main , if it was you should probably hear it on a cold start up also . If its still there get a stethoscope and check for the knock and where it is .
Old Oct 13, 2007 | 05:29 PM
longhungsilver's Avatar
Originally Posted by n4ynu1010
Replace the chain by all means , I guess that means if you have a cam belt that it is probably in the same shape , a chain or belt slapping would cause to me a different noise that a bearing knock , hope you don't have both , take care of the chain and or the cam belt (if you havn't replaced recently) and go from there , if you still have the knock then I would have to say go from there , hope its not a main , if it was you should probably hear it on a cold start up also . If its still there get a stethoscope and check for the knock and where it is .
cam belt?
Old Oct 13, 2007 | 05:30 PM
if your getting a knock its not from the chain that makes a slapping/grinding sound) or a growl. Use a stethoscope and find out where the knock is coming from before you go and do the chain... no sence waisting time if you decide to junk the engine
Old Oct 13, 2007 | 06:11 PM
n4ynu1010's Avatar
Originally Posted by longhungsilver
cam belt?
Overhead type
Old Oct 13, 2007 | 06:14 PM
n4ynu1010's Avatar
cam belt?
Modified / Edited , lost my mind there , have a chain and a valve timing belt hehe
Old Oct 19, 2007 | 02:33 PM
SC2WD's Avatar
How much slack in the timing chain is acceptable? I had the cover off to do the valves the other day and looked around, pushed on the chain with a screwdriver and everything looks fine to me. Then I realized I have no idea how much chain deflection is ok.--and I have that strange diesel rattle sound at start up .
'94 22re 80,000 miles
Thanks
Old Oct 19, 2007 | 04:19 PM
n4ynu1010's Avatar
Thanks
Heres the FSM Timing Chain Breakdown :
http://personal.utulsa.edu/~nathan-buchanan/93fsm/engine/8timingch.pdf
Did you get a look at your guide/tensioner and see how that looked , manual will show you
Old Oct 19, 2007 | 04:21 PM
n4ynu1010's Avatar
Thanks
And if it hasn't ever been replaced at 80K is a real good time to eliminate that problem
Old Oct 19, 2007 | 08:35 PM
yeah it locked up guys but its all good now all painted and readdy to get put back together yay
Old Oct 20, 2007 | 03:13 PM
SC2WD's Avatar
Thanks
I'll look through the manual and see how it looks. The guides looked fine. Couldn't see any broken pieces or anything...
Old Oct 20, 2007 | 03:23 PM
SC2WD's Avatar
Scheisse
Thats a lot of work. Is there any way to check the chain wear with just the valve cover off? Obviously, it won't be as accurate but...Like I mentioned above, what is the allowable amount of deflection? If there is no easy way, and if 80,000 seems like a good time to do it, I may just schedule the weekend and make it happen.
Thanks again,
JL
Old Oct 20, 2007 | 05:01 PM
n4ynu1010's Avatar
Timing Chain
Thanks again,
JL
If it were me and I had it down that far at 80K I know I would change it just so I know its good for a long while , they have a test in the FSM for it but you have to remove chain and measure links to determine stretch of chain , its like 17 links you measure and then spec's for measurement.
JNapolitano
Nov 14, 2019 07:46 PM
Flossy
Aug 5, 2015 05:14 PM
nonstop
Jul 24, 2015 06:29 PM
keithporter83
Jul 18, 2015 12:37 PM
