- I'm here for the rebuild
- alot of work to do!!
- engine vibration..??
- I pulled the codes
- Why does A/C cut out at idle?
- 2 hour project finished
- '88 yota
- Oil Pan Bolts and PS Pump drivin me crazy!
- tread wrights mounted
- trutrac or e-locker?
- Another 134A conversion question...
- Anyone running Ball Joint spacers in their rigs?
- Quick Shopping Help: 87 4runner??
- 91 4runner will not turn over Help
- [project] rebuild the wreckage
- [PROJECT] rebuild the wreckage
- Diesel engine options?
- Need help installing ARB bull bumper on 88 4runner
- Cylinder Head/Exhaust
- AFM testing
- conversion
- Project 30MPG 22R (86 SR5 pickup)
- What grade bolt for exhaust manifold?
- Gearing question
- Long Cranking (first start) -- air leak?
- The Great Swapathon! Clint's 90 Xtra Cab buildup
- fuel pressure prob?
- O2 sensor
- Doors
- body lift install problems
- 3VZE timing belt write up...my contribution
- help w/ very intermittent stumble
- Bent leaf spring bracket question
- 91 22 re 4x4 ?
- Long Travel Suspension questions
- Price for a 94 t4r?
- 86-88 Brush Guard on a 91?
- Weird way of lifting truck
- Can i???
- 22RE Valve Cover Breathers
- fuel filter
- 2nd Gen Aftermarket Gauge Locations?
- Engine Blown!!!! What to do???
- AC hoses
- No start condition
- Which HG?
- 3.0 air intake system
- Dust shield Removal
- Pcv Valve Location
- Misfire
- Control Arm Bushings
- Rear bumpstop removal
- not to brag but...........
- headgasket...FOR SURE
- Downey Long Travel Review
- Exhaust
- Need Help picking a "LIFT"
- Stripped spark plug hole
- 94 4Runner AC Problem
- spring suggestions?
- Fixing a Leaking Power Steering Pump
- DASH swap
- New 2nd gen 4Runner tail lights on the market!!!!!!!!
- problems again...gas
- EFI removal
- I just got a phone call...
- how loud do your valves tick on 22re?
- Need help removing manual hubs
- Need HEAVY DUTY Clutch
- 22re high rev noise
- 92 4runner 4cyl 5spd 7" lift as Daily Driver?
- 87 Turbo Pick up
- Tow trailer with 7" Lift
- How Much?
- glove box lock --84-88's
- 4runner is back on the road!! Pic....but a couple problems.
- What do you use?
- 22re rebuild
- Rough idle on cold start
- 95 4runner 3.slow no power
- Yet another Half Door post!
- Will a 31" tire fit in the stock spare location?
- 32x10.5 Interco TSL on 15x8 3.5 bs rims
- new guy needs help
- changing a cv...sigh
- Freeze12 / Oring question
- crappy idle
- which rear locker?
- check engine light on!!!
- I need this part 1990 3.0
- OME shock bushings
- HeadGasket recall question
- Why do Toyota's Ping??
- Engine noise
- SR5 Gauge Cluster
- starter just clicks after installing new hg
- head bolt torqure 22re
- Rear Leaf Opinions needed....
- Sweet smell?
- Timing belt, 3.0
- radiator flush question
- Clutch Master Cylinder Question
- 95 4unner + shaking/struggling around 55
- what leaf can i use
- Idle Question
- 89 Truck Shutters During Ignition
- Need to test your knock sensor?
- tread wrights ordered
- Rear Window - 89 Runner
- Steering Wobble
- Second Battery Install Q's
- Noob Alert: what to look for
- Woohooo new timing chain this weekend.
- 88 Turning Radius
- Chico's 85 toy
- got pulled over just now!!!!!! (read on)
- Head gasket job tips
- My bed is FUBAR
- Inner fender plastic lining thing
- PCV Valve
- 93' 4-Runner - blown head gasket- dealer have to repair?
- 87-88 A/C Installation Instructions Needed
- Is there suppose to be another gasket here? PIc
- Cigarette Lighter?
- Cracked Cylinder
- Radiator Recommendations
- So. Maine Toyota Stealerships!!
- O2 Sensors
- ECU/ ECM or brain box as i call it in a Ford
- Steering Stabilizer Replacement??
- help now PLEASE!!!!!
- Looking at a truck, ARB bumper fitment question, and exhaust questions
- Engine Done, i think?
- Low idle/dying problems
- No 5th gear
- Wash+Wax
- ok, who has done this?
- 2.4 swap
- Pro Comp Light Bar for a 91 PU
- 4.10 to 4.56 ...need convincing
- Tires Size with lift
- Vibration damper on the driveshaft ?
- 3vze DTC 14, lost power, cranks-won't start
- 150,000 miles 91 22re 4runner buy or not?
- Tacoma rear axle parts compatibility, '93 truck
- rear pinion bearing
- Exhaust fell off this morning... Anyone know the stud size?
- compression test results
- part # for starter contacts
- starter going out??
- Blue Picture Thread
- Power Windows and AC?Heater NOT Working
- Lookin A Part Number!
- Downey Header Question?
- Head gasket parts
- What do you think of this truck...
- signal lights
- Downey Headers vs. "Y" Pipe Mod?
- D-ring shackle through stock bumper hole for recovery purposes?
- Grant Classic?
- Wheel Noise
- lots of stuff
- Help, timing belt marks does not line up with cam/crank pulley and engine marks
- 60K Dealer Service
- Compression test results......
- I'll make the Chevy guy eat his words =0)
- i need help
- how does this work?
- More flex? Cutting down bump stops?
- 1985 Landcruiser EFI?
- Good Grief- shock question> Search, I know.
- Front Wheel Bearings: 2wd Runner
- Temp Sensor near Themostat
- Str* front conversion now tranny making noise
- Toyota 4x4 model
- LSPV Adjustment Questions
- 20 bucks 10miles and a saws all oh yeah!!!!!!! 56k be warned
- Rebuilt Motor. When to do interstate?
- Bad Day for my Yota
- 5spd swap writeup
- lock rite in front diff
- Boredom + spare grill + 10 bucks =
- interesting discovery
- Spare Tire Hanger
- Anyone have the full FSM.......
- detroit e-z locker problem
- Replacing Head Gaskets: Yes or No
- 16" Late rims on 1st Gen?
- machining flywheel (step/pedal feel)
- Tundra bucket seats
- 22r vs. 22re?? big difference??
- 2nd gen tjm owner question
- what do u guys think about this
- 22RE Timing Cover Bolt Length
- how to remove crank and cam seal -newbie
- body swap
- Approximate RPM's running 5.29's
- Cannot get power steering pulley off newbie
- what does the 40a fuse control in my 4runner
- fan clutch ?
- IFS wheeling videos (post them up)
- 89 pickup 22re stuck thermostat can it cause blown headgasket?
- am i the only one
- How hard is it to change out rear Ring and Pinion gears?
- Rear Diff
- 2nd gen OEM roof rack?
- Sputtering Like Hell.
- Power Steering Question *Pics*
- Radio, Clock and Cigarette lighter not working
- 4wd binds up!??
- Help! Exhuast Manifold/un known part related
- 89 22re online manual link
- Reincarnation of 22re w/ Total chaos pars?
- Attempting to kill last waterproofing gremlin (distributor)
- I want to remove cruise control
- auto to manual swaps parts list??
- This has got to cause poor gas mileage
- 86 A/C & Power Steering Pictures Please
- 93 2.4td Surf Intercooler question
- Lift Blocks + Parking Brake?
- oil used during/after break-in
- Oil weights...
- Hey, lucas guys.
- 86 22re vs 88 22re
- check valve?
- Bet You Can't Figure It Out!
- Big Score Today
- 4runner and pickup Same rear drive shaft?
- Highest lift for a 2WD
- 4mogger
- Oil problems!
- 94 22re swapped for 87 22re
- 3.15 Gears???
- Shell RotellaT synthetic 5w-40
- should PCV hose off cause truck to die?
- Need To Replace Fuel Gauge Sending Unit
- Best engine for longevity/fuel economy?
- welded rear gear..........
- Headlight Reminder
- 1995 pickup 22rec showing code 24 and 31 HELP!
- exhaust leak ???
- 22re doesnt start rain..
- 4runner doors on a pickup
- Freeze 12 Conversion
- Driver Side Window Adjustment
- Need help real quick...
- Man, memory slipping away. Gasket required here? Pic.
- License Plate / Reverse Light removal???
- exhaust question
- The 3vze Removal Write-Up
