Fixing a Leaking Power Steering Pump
Old Jun 1, 2008 | 01:41 PM
surf10's Avatar
Need some help here guys. I have a '92 4Runner with a leaking power steering pump. It's leaking where the fluid reservoir mates with the pump. The bottom of the reservoir has a short metal tube that inserts into a hole in the top of the pump. The rebuild kit comes with a small o-ring that seals this joint. But my questions is; is this o-ring supposed to stay in the grove machined in the short pipe, or are you supposed to just push the o-ring all the way up the pipe so it rests up against the bottom of the reservoir? Thanks a million for your help!
Old Jun 1, 2008 | 01:47 PM
abecedarian's Avatar
in the groove so it seals the tube to the housing.
Old Jun 1, 2008 | 04:19 PM
toytech76's Avatar
Buy a reseal kit from toyota and reseal the whole pump as it will start to leak on you at some point
voiddweller
19
May 2, 2016 09:10 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
Lybrium
Jun 29, 2015 12:19 AM
1badyota350
Jun 28, 2015 06:50 AM
paxanders
Jun 21, 2015 06:29 AM
