compression test results
Old May 28, 2008 | 05:56 AM
camo31_10.50's Avatar
ok..so we did the compression test on our brown '86 this past weekend...and it was surprising...
cyl. 1=165
cyl. 2=200
cyl. 3=200
cyl. 4=200
thats odd for them to be that high...isnt it...i've never seen a yota with over 180...in fact thats almost the highest compression i've seen on a 4x4 truck..that isnt modified...of course the 22R has been rebuilt abotu 35,000 miles ago...the mechanic says that its ok..i didnt think there was supposed to be a big variation in the readings...it still spits and sputters...but doesnt die...it died because of a vacuum leak under the breather...
Old May 28, 2008 | 06:20 AM
zlathim's Avatar
They do seem a tad high... but really the problem is the difference in cyl #1. Looks to be about 17-18% lower than the rest.
I recommend doing a cylinder leakdown test on cylinder #1 to find the source of the compression leak.
Old May 28, 2008 | 08:04 AM
anybody else???
Old May 30, 2008 | 07:22 AM
ok..so what the hell is wrong with my truck....sometimes it will run fine...other times it will blow blue and white smoke...and have the power as if its running on 3cylinders...anybody have any ideas....
Old May 30, 2008 | 01:21 PM
bump...anyone
Old May 30, 2008 | 02:35 PM
76ANTHONY's Avatar
HEY I GOT 4 CYLINDERS AT 150 AND TWO AT 10, so ima build an engine, dammit
Old May 30, 2008 | 08:43 PM
91Toyota's Avatar
Blown head gasket?
Old May 30, 2008 | 08:48 PM
abecedarian's Avatar
How do the plugs look?
The compression appears ok on #1 but the others are a tad high.
Pardon me if you've mentioned it before elsewhere, but have you done any work on the engine recently?
_Nicco_
Sep 21, 2015 03:06 PM
LotOMiles
Sep 14, 2015 11:45 PM
JHalcyonM
Sep 14, 2015 01:10 AM
sanctfy
Sep 13, 2015 06:33 PM
some drunk guy
Sep 4, 2015 11:55 PM
