Front Wheel Bearings: 2wd Runner
Old May 26, 2008 | 08:41 PM
qdude79's Avatar
About 155K on what I assume are the original bearings/races. Should I forgo inspection and just replace with those miles? If so, do the races need to be pressed out as well, or can I get them out/in myself? Vehicle doesn't seem to have excessive wear or mechanical abuse by PO...
Thanks
Old May 26, 2008 | 08:47 PM
Jay351's Avatar
Inspect them first:
Jack up wheel, grab tire at the 8 and 2 oclock posistion and try to wiggle it. If there is movement then they need to be re-packed.
Old May 26, 2008 | 08:59 PM
Matt16's Avatar
I didn't think 2wd had front wheels. What are they for?
Old May 26, 2008 | 09:00 PM
Jay351's Avatar
... oh wow that made me laugh, thanks Matt!
Old May 26, 2008 | 09:04 PM
jason191918's Avatar
Originally Posted by Jay351
Inspect them first:
Could be ball joints...
Old May 26, 2008 | 09:06 PM
Matt16's Avatar
Old May 27, 2008 | 07:26 AM
qdude79's Avatar
That pics pretty accurate, especially since my ride's blue! That being said, back to the original question: Do I even inspect the horseshoes, or just replace them with them being that long in the tooth?????
Old May 27, 2008 | 07:29 AM
qdude79's Avatar
Also, whether replacing or repacking, how much grease do you leave inside the hub? I can't imagine you fill the thing, that'd be a TON of grease.
Lastly, if replacing with new, do the races need to be replaced as well? If so, can I do it myself or do they need to be pressed in/out?
Mister Ed
Old May 27, 2008 | 09:08 AM
eric-the-red's Avatar
I would check the bearings before deciding whether to replace them. Clean all the grease off and look for any rough spots or signs of overheating on the races.
The grease amount kind of comes with experience, you don't want to pack it full though. Make sure the bearings are thoroughly packed and put some in the hub. I usually put a ring about 1 cm wide on the inside of each bearing.
And if you do replace them the bearings and races are a matched set, DO NOT use new bearings with old races. The races can usually be tapped out with a brass rod, just go slow and work around in a circle so they come out square. Same deal with installing the new ones.
DanStew
Jun 29, 2015 10:46 AM
YotaGreenhorn
Jun 27, 2015 07:00 AM
Mr.Black
Jun 21, 2015 10:17 AM
Mohamed
Jun 20, 2002 10:42 AM
UKMyers
10
Jun 14, 2002 12:42 PM
