Sweet smell?
Old May 30, 2008 | 04:29 PM
1992toyota4x4's Avatar
Sweet smell?
Hey guys, lately, and since i bought my truck, i have noticed a sweet smell coming from the exhaust, i have changed the motor, and still notice it a bit, sometimes more than others. i have never smelt burning prestone so i dont know if its that, and also my truck never overheats, or never goes over half for that matter, i never have to add prestone, and it never smokes. so what could it be, its a smell thats hard to describe, but noticeable. any one else experienced this? i do have leaky cam and crank seals i believe.
92 pickup
4x4
3.0l
thanks for any input.
Old May 30, 2008 | 04:30 PM
bigt's Avatar
antifreeze smells sweet. if its a 3.0 headgasket
Old May 30, 2008 | 04:31 PM
ya but did u read where i said it never over heats and never have to add prestone.
Old May 30, 2008 | 04:32 PM
Crawdad's Avatar
More than likely antifreeze. Time to do a compression/leakdown test.
Edit: It doesn't have to run hot to be a headgasket. Not yet, anyway. If you have a tiny leak from the water jacket to the combustion chamber, it will burn only a few drops (enough to smell sweet) without looking low or causing overheating. A tiny leak leads to a big leak which leads to a ruined engine if you don't catch it quick, so I would check it out as soon as possible.
Get a borescope and look down in the combustion chambers. If they're shiny (ie - no carbon on the piston tops or valves), you have a coolant leak into the chamber.
Old May 30, 2008 | 04:33 PM
bigt's Avatar
yes but you gotta undearstand not much eles would smell sweet in your exhaust... and we dont have smelloweb yet
Old May 30, 2008 | 04:50 PM
CJM's Avatar
CJM
Antifreeze is the only liquid in a vehicle that smells sweet, you need to do a leakdown and compression test.
Old May 30, 2008 | 05:01 PM
how much is a new head gasket, and how many hours to change it?
Old May 30, 2008 | 05:07 PM
Matt16's Avatar
Its a big job. If you can afford to, and you are reasonably mechanically inclined, try swapping in a 3.4L V6.
Old May 30, 2008 | 05:10 PM
JDMSLIK's Avatar
https://www.yotatech.com/forums/f116...-parts-146181/
I recently had a good experince with the local toy dealership
Old May 30, 2008 | 05:11 PM
bigt's Avatar
yeah but it might no be the head gasket sometimes a little gets through.
as the previous postered said..
IT MIGHT BE NOTHING!!
Old May 30, 2008 | 05:26 PM
has anyone ever heard of or used that "heal a seal" stuff that is supposed to fix any internal leaks? maybe some of that would stop mine, since its such a small leak?
heres the site.
http://www.heal-a-seal.com/
Old May 30, 2008 | 05:45 PM
scratch my last post, i looked into that heal a seal stuff, and no one said it works, ripp off company.
Old May 30, 2008 | 05:48 PM
bigt's Avatar
yeah.. dont worry too much but i would check the compression.. did you say this was a rebuild engine??
i have a 4runner i got from a guy at work 22re and i still dont trust the rebuild he had and i always have thoughts about putting insurance back on the trail rig!! even though its gutted and ugly...and my dd is a bueat
Old May 30, 2008 | 05:54 PM
no this isnt a rebuild engine, this is an original engine, its got about 180000k on it. i believe the head gasket recall was done... but i wonder, if it wasnt done on this engine, would i be able to have it done even though its in a different truck?
Old May 30, 2008 | 06:02 PM
bigt's Avatar
it wasnt rebuilt when it was installed??
id look into a 3.4 but i tottal wouldnt have the cash either
Old May 30, 2008 | 06:05 PM
i installed it a few months ago
Steven.m.paulk
Jun 7, 2020 10:45 AM
puddlepirate
Jul 30, 2016 06:29 PM
Buckaroo_Banzai
Sep 24, 2015 07:26 AM
Ott47
Sep 14, 2015 12:09 PM
