1989 Pickup Cluth/transmission issues?
Old Sep 14, 2015 | 11:54 AM
Ott47's Avatar
I could not find anything to help myself by searching but I just had this strange problem with my toy. I was going to work today and while I have no issues getting it into gear, when you try to accelerate the RPM's will rise and the truck would slowly get to a top speed of about 40 mph. I stopped at a stop sign and then the RPM's would just raise but no movement from the truck. I am trying to figure out if this would be a clutch or a transmission issue? any advice would be helpful, you could also smell something burning, but strangely to me it smelled more electrical than anything.
Old Sep 14, 2015 | 12:01 PM
millball's Avatar
Time for a new clutch.
Old Sep 14, 2015 | 12:02 PM
Ott47's Avatar
should I even try to replace the slave/master cylinder or just go straight for the clutch?
Old Sep 14, 2015 | 12:08 PM
millball's Avatar
There is no common failure mode of the clutch master, or slave cylinders that account for severe clutch slippage.
As an adjunct to clutch replacement, you may well replace the hydraulic cylinders if they are well used, or show any leakage.
Have you got oil leakage that might be attributable to a rear main seal leak or tranny input seal leak??
Clutches hate oil.
Old Sep 14, 2015 | 12:09 PM
Ott47's Avatar
HA, as a matter of fact I do have a leak that could be contributed to a rear main seal
bigjstang
Jun 2, 2025 03:56 PM
Regency
20
Jan 3, 2020 07:43 PM
mskalmus
May 28, 2017 07:51 AM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
Nickdigg
Jul 7, 2015 06:04 AM
