SR5 Gauge Cluster
Old May 30, 2008 | 06:17 PM
cosmo's Avatar
SR5 Gauge Cluster
I just swapped in an SR5 gauge cluster from a '92 4Runner into my '93.
Everything works fine, except that the tach reads about 1000-1500 RPM too low. I believe the cluster came from a V6 model. Is there any way to get it to read the correct rpm?
Old May 30, 2008 | 07:06 PM
just a 22re's Avatar
yeah theres a away but im not sure i belive its something to do with something in the back of the gauge or trade it for a 22re cluster does the back of the cluster say 22re on the wire tape (the green thingy on the back) or does it say the v6 name
Old May 30, 2008 | 07:21 PM
cosmo's Avatar
I'll check it and let you know.
thanks for the reply.
Old May 31, 2008 | 06:06 PM
so cosmo whats you find?
Old Jun 1, 2008 | 10:24 AM
cosmo's Avatar
I'm not finding any markings on the wire tape... any other identifiers?
It almost certainly is from a V6 since it reads too low.
Old Jun 1, 2008 | 12:54 PM
i think the 22re ones said 22re on the ribbon tape on the back the big green thingy but yeah i think its from a v6
and sorry i dont know how to make it work for a 22re but i have read it somewhere where they did do it and it worked
Old Jun 1, 2008 | 01:29 PM
rowdy235's Avatar
yeah Allan I think I read that too. But by the end of it I figured it would be so much harder, i'd just get a 4 cylinder one.
Old Jun 1, 2008 | 01:44 PM
'884Runner's Avatar
Auto vs. Manual trans
I have considered a similar swap for my '88 22r-e 5 speed, and know where to get a tach from a 22r-e auto. Is there any reason this will not work?
Old Jun 1, 2008 | 02:31 PM
foot0069's Avatar
Check this out
Jim
https://www.yotatech.com/forums/f116...ctures-102656/
Old Jun 1, 2008 | 05:16 PM
cosmo's Avatar
so what do I do to take the cluster apart...
I assume I need to push the plastic tabs in and pull it apart.
Old Jun 1, 2008 | 06:49 PM
cosmo's Avatar
still can't get the cluster apart...
Old Jun 1, 2008 | 07:08 PM
ok to get the cluster apart if i remember right you have to take a flat head and push the clips out one at a time and unscrew the trip reset thingamabober and then you can unscrew the gauges from the back if you have a picture of this cluster i can show you by reposting your picture with the right way to remove it
Old Jun 1, 2008 | 07:20 PM
cosmo's Avatar
finally figured it out. took everything apart and turned the adjustment screw forward, but now the tach doesn't work at all...
mussy01
Dec 13, 2016 08:20 PM
gary4runner
Sep 24, 2015 12:53 AM
highonpottery
Aug 25, 2015 03:45 PM
mund1011
Aug 16, 2015 07:10 AM
Esibnitsud
Jul 30, 2015 08:21 PM
