Can i???
Old Jun 2, 2008 | 01:07 PM
toyta15's Avatar
Can i???
Hey im taking a lift out of a buddys 1990 toyota truck and im wondering if the ifs changeg at all and if it will fit in my 1987 toyota 4 runner.... if so is it hard is it to put it in with the toyota ifs???
Old Jun 2, 2008 | 01:21 PM
Jay351's Avatar
In short, yes. All parts should be compatible...depending what kind of lift you are talking about.
Old Jun 2, 2008 | 07:11 PM
just a 22re's Avatar
84-89 used rear leafs 90 and up uses coil springs!!!!
but the front in all shortness is the same
Old Jun 2, 2008 | 07:59 PM
Matt16's Avatar
He wants to put a lift from a truck onto a leaf sprung 4Runner. Both have leaves, so it shouldn't be a problem.
Old Jun 2, 2008 | 08:12 PM
BAZ's Avatar
BAZ
Arent the truck leaves slightly longer than the 4runners?
Old Jun 2, 2008 | 08:23 PM
YeloSub7's Avatar
Yes the front IFS and the leaves will work for you!
Old Jun 2, 2008 | 08:26 PM
Matt16's Avatar
You may be right. I don't know. Unless its a spring lift (OME etc), it should work regardless. Shackle and blocks would be interchangeable I'm almost certain.
