crappy idle
Old May 31, 2008 | 06:27 AM
flatbedyota's Avatar
crappy idle
1986 22re and my idle has never been great its always been a little rough....the other day i pulled the vacuum line off of the FPR and my idle smoothed out and it idles great now....could my FPR be bad??
Old May 31, 2008 | 08:19 AM
abecedarian's Avatar
I know, dumb question, but did you plug the vacuum line when you disconnected it?
Old May 31, 2008 | 08:24 AM
i did it either way and both ways it ran the same...better well smoother i havnt driven it down the road with the line off...and the return line on the FPR if i take it off while its running it pours gas out wich i think it is supposed to do
Old May 31, 2008 | 08:36 AM
actually sounds like the pressure regulator is working since the engine operation changes when the vacuum line is disconncted. so you may have a defective fuel up vsv, (it's at the other end of that vacuum line, blue in color I believe,) applying vacuum when it shouldn't.
Old May 31, 2008 | 08:43 AM
4Crawler's Avatar
The FPR needs the vacuum line to reduce fuel pressure when the engine is under light load/high vacuum conditions. I just connect mine directly to the intake, eliminating the VSV:
http://www.4crawler.com/4x4/CheapTri...ne_Pix/10.html
If disconnecting the vacuum from the FPR helps it idle smoother that might mean you need more fuel pressure at idle which might mean the fuel injectors are clogged and need the added pressure to inject enough fuel at idle. On my '85, if I unplug the vacuum line to the FPR, it runs rougher at idle and the engine loads up when you rev it until you hit about 2500 RPM.
Might want to test your Throttle Position Sensor to see if it is adjusted properly:
- http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml
the line runs up to a switch its got another vacuum line coming off of it and an electrical plug on it....i assumed it was a vacuum switching vavle but wasnt for sure...is there ne way to test it besides replacing it??....thanks for the help
Old May 31, 2008 | 08:47 AM
4Crawler's Avatar
The VSV is like a relay for vacuum. Test coil for continuity, check ports for clogging and then you can try blowing through the VSV to see if it works. W/o power I think the flow is input/vacuum to the FPR and with power, the vent line to the FPR:
Or, just bypass the VSV.
Old May 31, 2008 | 09:08 AM
i like the sound of bypassing it...how exactly would i do that...i dont know if it matters but i blocked off my egr
Old May 31, 2008 | 09:09 AM
4Crawler's Avatar
Look at the first picture I posted as well as the web page link. In short, take vacuum line that used to run to the VSV and plug it into the FPR instead.
Old May 31, 2008 | 10:15 AM
ok..but what do i do with the other vacuum line on the vsv and do i just leave the vsv plugged in or do i unplug it???...thanks
Old May 31, 2008 | 10:43 AM
4Crawler's Avatar
Whatever, bypassing the VSV means that it no longer serves any purpose nor does the vacuum line hooked to it nor the wires hooked to it.
I cleared all the stuff off of mine:
Saved the VSV as a spare.
Old May 31, 2008 | 11:15 AM
Just though of something... if disconnecting it makes the fuel pressure rise and the engine run smoother, there could be a vacuum leak somewhere else causing the rough idle when the fuel pressure is lower.
Old May 31, 2008 | 11:36 AM
ok i will try that when i get off of work and see what it does....im not saying there is not a vacuum leak, but i just replaced all of the vacuum lines on the truck
Old May 31, 2008 | 11:47 AM
4Crawler's Avatar
Put a vacuum gauge on there and see. They don't cost that much and are handy for testing/troubleshooting.
Blamalam
Mar 12, 2022 07:34 AM
Marsheen
Feb 17, 2016 12:29 PM
GrimWolf
Aug 28, 2015 03:36 AM
Sarcazmo
Aug 15, 2015 08:22 PM
priest16
15
Aug 6, 2015 07:43 AM
