Spare Tire Hanger
Old May 26, 2008 | 12:34 PM
qdude79's Avatar
Spare Tire Hanger
'90 'Runner, 2wd. Am running the stock cookie cutters, thus allowing me to keep the spare in it's original location in front of the rear bumper. While doing other projects, went to take down the original spare and realized that I don't have any of the Toyota tools used to "crank" it down. What hardware am I missing to get this thing down the way it was intended??? I don't have the original owner's manual, either.
Thanks!
Old May 26, 2008 | 01:04 PM
Junkers88's Avatar
There is a long rod with a semi closed end that you use to lower the carrier (if trucks and runners are the same). You're best bet would be to go to a junk yard and look in the Yota's there. I'm willing to bet that some still have the rod in them. In the extended cab trucks they are located under the back deck mounted on two small clips. I don't know where they are in the runners.
Take care and good luck.
Old May 26, 2008 | 01:17 PM
JonnyBoy's Avatar
Under the back seat in 'Runners
Old May 26, 2008 | 01:50 PM
notjustatoy's Avatar
^^ GO TO A JUNK YARD!!! You know better than that!
There aren't any Yota's in a junk yard!
I'm having the same problem. You link two rods together and go thru a hole in the back to "turn" the spare down. Mine is so rusted that i have ruined the two rods and the spare is still on there.
ANY IDEAS???
Old May 26, 2008 | 02:30 PM
scuba's Avatar
ANY IDEAS???
cheers
https://www.yotatech.com/forums/f2/r...chanism-53949/
Old May 26, 2008 | 02:37 PM
rowdy235's Avatar
on my old truck it was seized. 2 days of PB blaster, liquid wrench, wd-40, deep creep, etc. and I still ended up just bending the rod more and more. Finally tried to use heat to un seize it with no luck, so I just threw in the towel and torched the chain. Always meant to get one from a junkyard but never got around to it.
Old May 26, 2008 | 03:01 PM
HAVOC's Avatar
My hanger is also stuck, but seeing that it's the cable type I should be able to get the spare (which is no good) down. If you have the "chain" type you should think about getting the "cable" type instead.
Old May 26, 2008 | 03:04 PM
HAVOC's Avatar
Would you prefer "outdoor parts warehouse"?
Old May 26, 2008 | 05:05 PM
qdude79's Avatar
There it is, under the rear seats! Gonna hit the mechanism with some penetrant ahead of time. Much thanks!
Flying91
45
Apr 11, 2024 04:39 PM
Jcrawl94
10
Oct 24, 2015 04:34 PM
mr_manny
Jul 31, 2015 10:39 AM
skoti89
Jul 8, 2015 12:05 AM
