engine vibration..??
Old Jun 3, 2008 | 05:08 PM
orbital02's Avatar
I have a vibration in my 4runner when I rev the engine to 2400-2900 rpms. This vibration is in any gear. Any thoughts?
Old Jun 3, 2008 | 05:21 PM
TOYOTA 1's Avatar
does it do it in nuetral? if so, maybe your clutch? i mean i guess a piece of your disc could have come off and now its out of balance? or you have a bad motor mount?..... just some ideas!
Old Jun 3, 2008 | 05:28 PM
abecedarian's Avatar
+1 on the possible motor mount
clutch? possibly.
vibration dampener on the crank? could be.
misfire? maybe
Old Jun 4, 2008 | 09:21 AM
orbital02's Avatar
thanks for the ideas. I pretty sure its not a misfire. Its an auto so no clutch and the when I stick a pry bar in between the mounts and the frame, it vibrations even more. So im not sure what that means. As far as the crank damper... I dont know but how could I check>???
Old Jun 4, 2008 | 09:22 AM
CJM's Avatar
CJM
Motor mounts, trans mount, out of phase or balance driveshaft, bad u-joints, bent axleshafts, out of round wheels or tires can all cause a vibration.
Old Jun 6, 2008 | 07:42 PM
orbital02's Avatar
All of those wont matter since it vibrates in park when the truck is not moving. One new thing I noticed is that around 1700 rpms the truck vibrates in delayed intervals. For example, it will vibrates very slightly for a second, then nothing for a second, then back to vibrating for a second and so on. It still vibrates around 2400- 2700 rpms as well. I mean... It has to be engine related and i dont know what engine part it could be since they are all new. Actually I did break an injector wire inside the plug so I just wired the injector up without the plug. It seemed to work fine, but maybe its causing some interference or resistance issues??
Old Jun 6, 2008 | 07:49 PM
CJM's Avatar
CJM
Motor mounts...
icentropy
Sep 16, 2020 02:47 PM
RaginAsian91
Engine Swaps
Mar 30, 2019 09:17 AM
jasonty
41
Dec 23, 2018 01:00 PM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
razorman8669
Jul 12, 2015 12:13 PM
