What grade bolt for exhaust manifold?
Old Jun 2, 2008 | 07:17 PM
GenXr's Avatar
I've searched and found that the exhaust manifold studs/bolts are 10mmx1.25 and you can use 50MM ~ 60MM in length to try and catch the extra threads in the hole......but what grade bolt should I use? Grade 5 or grade 8? (metric equivalent of course)
Thanks.
Old Jun 2, 2008 | 07:45 PM
Noltz's Avatar
Five is plenty. It's not structural, just holding the parts in place.
Old Jun 2, 2008 | 07:57 PM
Matt16's Avatar
What ever is cheapest. The head is aluminum, so its not torques too high anyways. Also, make sure to use a stud and nut, not a bolt, again, as it aluminum which strips easily.
Old Jun 3, 2008 | 01:57 AM
thook's Avatar
Ain't that the truth. I have two helicoils for my manifold already.
There are two bolts, btw. But, they're only for the manifold plates. Otherwise, I concur...use studs. 4t for non-grooved.....6t for grooved. The groove will be on the end of the stud, if there are any.
Edit: I'm pretty sure it's 4t on the exhaust. 6t would have be for wheels studs.
Old Jun 3, 2008 | 08:09 PM
Pistonman's Avatar
I always use new Toyota studs and nuts for trouble free operation.
Blamalam
Mar 12, 2022 07:34 AM
tj884Rdlx
Aug 28, 2015 12:04 PM
whereAreMyPants
Jul 22, 2015 03:32 AM
87blyota
Jul 10, 2015 04:31 AM
