What grade bolt for exhaust manifold?
Old 06-02-2008, 07:17 PM
GenXr's Avatar
I've searched and found that the exhaust manifold studs/bolts are 10mmx1.25 and you can use 50MM ~ 60MM in length to try and catch the extra threads in the hole......but what grade bolt should I use? Grade 5 or grade 8? (metric equivalent of course)
Thanks.
Old 06-02-2008, 07:45 PM
Noltz's Avatar
Five is plenty. It's not structural, just holding the parts in place.
Old 06-02-2008, 07:57 PM
Matt16's Avatar
What ever is cheapest. The head is aluminum, so its not torques too high anyways. Also, make sure to use a stud and nut, not a bolt, again, as it aluminum which strips easily.
Old 06-03-2008, 01:57 AM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
Ain't that the truth. I have two helicoils for my manifold already.
There are two bolts, btw. But, they're only for the manifold plates. Otherwise, I concur...use studs. 4t for non-grooved.....6t for grooved. The groove will be on the end of the stud, if there are any.
Edit: I'm pretty sure it's 4t on the exhaust. 6t would have be for wheels studs.
Old 06-03-2008, 08:09 PM
Pistonman's Avatar
I always use new Toyota studs and nuts for trouble free operation.
Blamalam
03-12-2022 07:34 AM
tj884Rdlx
08-28-2015 12:04 PM
whereAreMyPants
07-22-2015 03:32 AM
87blyota
07-10-2015 04:31 AM
Quick Reply: What grade bolt for exhaust manifold?
