- half Bumper Idea... Pictures
- it's alive again!!!
- What is My 4runner worth?
- Rear Diff Fluid
- 1st Gen 4Runner Questions
- timing puzzle
- 94 runner
- Water temperature sensor - looking for replace part code (factory)...
- aftermarket power window kits?
- Engine Trouble Code (14)
- Im back haha
- Brakes will not bleed, HELP!!!
- Alternator upgrade questions
- Installing factory p/w & P/L
- C-V boot question
- rough idol
- 22R-E question
- Bad Bad Gas Mileage
- What is YOTATECH nicest 85-95 pickup? POST THEM
- parts?
- What kind of Spray Lube for engine compartment
- SAS lift/tire chart?
- how else can i get lift?
- Weird Rubbing?
- My 1" Body Lift Write Up
- No more Yota
- CV Boot/Halfshaft Replacement Help! 1993 4runner
- Finally got pics up of my 91
- got a 4runner, did i get a good deal???
- Door panel swap
- Coolant
- Is it a Game????
- get rid of crossover pipe
- por 15 to reenforce plastic trim?
- E-Locker info
- Incline meter/ altimeter
- What is idle while in Drive with auto 3.0
- spare tire ???
- manual locking hub options.
- Thanks Yota, look what I bought!
- Crankshaft Pulley Bolt
- Aux Fuel Tank For 2nd Gen! On E-bay
- Pinging on Partial Throttle
- 3.0 is starting to act up.
- high NO reading and GETTING higher
- 22re valve cover torque specs
- White Smoke?
- Anyone else get the All-pro Tripple X crossmember and e-brake combo?
- V6 with Oil in the cylinders
- head gaskits!!!!
- Installing 1" Body lift tomo, any tips?
- Locker Confusion
- 4Runner tail light covers?
- This bolt is kicking my ass!!
- Red Bushings .
- 3vze Help
- searchin but not findin...ditch the A/C?
- what this wire
- 86 Turbo Runner
- Speakers in Door; a problem
- code 25- pair system?
- please help, 2nd gen sounds weird
- master cylinder differences
- rear axle Q
- Factory rear LSD not working...can be repaired ?
- 80 AMP fuse trashed
- A few questions before I finish my Head Gasket.
- To comfort me on rollovers =)
- timing belt, 1988 3.0- how to ?
- transfer case shifter won't go back in
- Craigslist Find kinda
- Diff lock/gears
- Tranny!!!!
- Differences between an 81 22r and 93 22r
- Fuel Injectors
- BJ spacer ?
- Rear bumper with receiver pics
- Rocker Arm Assembly
- What am I whobbeling?
- Anyone wheelling in RI area????
- Throttle body hose crack and other ?s
- timing
- Vacum Hose Diagram?
- Engine Noise
- Vacum Hose Goes WHERE!?!?!
- Truck Cap pics?
- My New Truck!!!
- Help me Identify this...
- Need 22re engine bay pics
- Exhaust Breakage
- New to Truck brakes???
- Diff. match
- 1995 4Runner 3.0 vze engine from hell!!! help
- i cant find the power window circuit breaker
- Timing Nightmare
- Powdercoat Alum. Wheels
- 4runner camper hoist options?
- 22re Rebuild questions.
- could this be a water pump?
- 88 p/u cant get into gear
- Starts but will not run without pedal '88 PU
- Help with spindle bushing/bearing upgrade
- grrr failed sttering wheel lash inspection.
- Driveshaft vibes after pinion seal...
- Attn: 3VZE cam timing experts
- interchangeable caliper question
- Anyone make replacement body mounts?
- Lound Clunking noise under truck when driving?????
- fiberglass fenders
- 22re not getting fuel???
- Disconnect sway bars
- why does my 4runner sputter in low rpm
- Transmission replacement.
- axle Q
- The EFI fuse
- Does any one make a cold air intake for 86 22RE
- roof rack info needed!
- bad rings or bad valve stem gasket CONCLUSION!
- turbo
- which gasket graphite or mls
- BJ spacer pics anymore like this and how much did you guys have to cut out?
- Failed Emissions Again
- keep or sell
- BJ Spacer Questions Suspension Geometery
- Hello and thanks so far! (new member)
- Speedo Cable Part Numbers
- 93 22er
- Any one using the Downey rear prerunner bumper???
- Can I bolt in??
- Removing o2 sensor? any help appreciated
- v6 diff question
- Ride rite bags with lift springs
- 2nd gen runs rough
- Was my transmission swapped?
- Unstable on freeway
- Arkansas Wheelers
- Anyone running Doetsch Tech shocks?
- magnaflow: 3 chamber or straight 18"
- Whats more reliable?
- '92 'runner alternator questions
- will a '04 taco trd elocker diff mount up to mine?
- 22 R Bad Rattel in engine Please help its my everyday driver
- rear axle alignment?
- 94 4Runner starting and running problems
- SR5 gauge swap
- need rear axle housing
- I've searched, dug through piles of pics..nothing...84-89 w/roof racks or light bars?
- 87 turbo Wheeling for the first time, issues.
- dash lights
- Very lean yet still gobbles fuel (long)
- HELP Engine studder at 2500rpm after TB replacement
- About to do my rotors
- Craigslist- K&N
- Any other ways to figure out gearing?
- Transmission won't come off??????
- Hose and/or vaccuum line kit??
- Find 86 4runner FSM Where?
- Rebuilt 86 22RE quit running and will not start
- What is this gasket called and where do I get it?
- 87 4 banger
- Loose wires. Where do they go?
- Adjusted valves, now ticks louder?
- Questions. Questions. Questions.
- Halos for Gen 2
- bumper question
- BJ spacers vs. Cranked T-bars
- Salage yards in Colorado Springs
- Rear window problems
- Master Cyl. Question
- rolling cargo cover for 2nd gen?
- questions on 3vze hg replacement...
- Best rock sliders?
- poking my eye out!!!!!!!!!
- Stock alternator or upgrade for dual battery setup.
- clutch and throwout bearing question
- What size is this bolt?
- driveshaft wobble/vibrations
- denso wires
- My coolant temp gauge never works......88 4runner with the 3.0
- 22re loss of power issues...some questions.
- this is a stupid question...
- Dash Lights in my 91
- 22 r timing question
- Secret to shock removal?
- downey tube rear bumpers? How sit mount...post pictures!
- Tranny
- coil springs
- does anyone have any tips on painting frames
- does anyone make a lager bore throttle body for a 3.0
- i wanna hear some motor oil arguments
- how should i break in my 3.0
- WHAT in the world are these? Metal brackets of some sort..
- how to remove trailor hookup?
- traben27's going to moab
- ECT Button on 95 4runner
- Chev V8 swap ?
- doesn't turn over, just clicks
- Child seats and bench seats
- Well I bought em.....
- 1991 4runner suspension advice need help
- All the ticking!!
- Transmission getting hot?
- just me being me
- 4runner or pickup????
- Bad Brake Line...
- Help!!!add To Manual!! Help Please
- Slapping/Clanking
- replacement body parts
- The Ballinest Tire Ever
- Has anyone used a lumber rack on 1st Gen?
- How can I make my own exhaust?
- Is new seat foam available?
- I like to dance, just not at idle
- Are Denso OEM and aftermarket spark plug wires identical?
- Need a muffler, 3.0. sound byte inside
- Windsheild decal
- Windshield Trim
- need help diagnosing check engine light
- photoshop...Desighn a stripe for my truck!
- auto tranny question?
- Fuel pump relay?
- Just in time-New tires!
- axle bearing retainers?
- Front CV Axle
- napa tru view headlights installed
- bad rings or bad valve stem gasket?
- 3.0 Running WAAAY to rich.
- Flywheel + bellhousing
- Window Channel Supplier
- Whats this tube coming out of the valve cover..to the intake?
- 2gen help
- Bj Spacers!
- trans removal question
- Calling all lockrite guys
- sr5 gauge cluster.. or aftermarket?
- What size engine bolts?
- 1994 truck 22-re poss. clutch problems
- 4 runner hard starting/sputtering
- Driveline hitting gas tank.
- 3.0 to 22r/re swap
- Muffler advice
- Funky noises, water pump?
- What shocks?
- 2wd vs 4wd axle ?s
- Ok Guys I Cant figure this out...
- Engine Chain Condition
- Front Swaybar Remove or Keep?
- Wheel Stud Dimensions
