Help me Identify this...
Old Nov 17, 2007 | 01:41 PM
Sactown4x4's Avatar
I need to know what goes in there, color, what to where? where to what? Bought the truck like that, first yota truck also, clueless... so help guys, i know for sure my signal lights don't work, if i can get that to work, then i can be on the road no problems.
thanx in advance
oh yeah... forgot to mention, it's an 87 4x4 yota truck, last owner changed the dash and cluster also.
Old Nov 17, 2007 | 01:53 PM
Shoua's Avatar
I believe only certain connectors will fit in those, if anything even goes in those. Looks like you're missing a few fuses as well?
Old Nov 17, 2007 | 01:54 PM
SCYOTA's Avatar
It should only fit on one of the male connections. Look at the terminals on the plug and match it up with the terminals on the fuse box. It might be that they wont fit up at all if the cluster was changed but I don't know for sure.
Old Nov 17, 2007 | 02:36 PM
billmaness's Avatar
Remove the mounting bolt(s) and look at the back of the fuse box. That may tell you if they are even wired/needed. If you have the lid, that should tell you what the fuses are for. Trace the wires on the back of the box.
Hope this helps.
Old Nov 17, 2007 | 05:36 PM
Sactown4x4's Avatar
thanx guys
You guys ROCK!!!!!!!!!!
THANK YOU
Corvoid
Oct 13, 2015 08:55 AM
JUICE222
Oct 13, 2015 08:50 AM
Bill854x4
Sep 20, 2015 04:32 PM
jdt79
Sep 16, 2015 02:14 PM
DadsTruck
Aug 1, 2015 09:14 PM
