shaving bump stops
Old Nov 10, 2007 | 10:29 AM
algranger's Avatar
shaving bump stops
hey, i have ifs :cry: and i wanna shave down my front and rear bump stops but what bad things could happen if i do? how much could i shave off? thanks
Old Nov 10, 2007 | 10:41 AM
infiltrator's Avatar
nubie question but what exactly is a "bump stop"?
Old Nov 10, 2007 | 11:01 AM
8yota9's Avatar
they are on the a arms and up front and in the leavs and frame round back. the stop the wheels from to much travle if i am corect. i dont no about shaving them. but i have ran it thro my head i would say like 3/4" is the max maby less. im sure some one will chime in with a good respons.
Old Nov 10, 2007 | 11:09 AM
elripster's Avatar
You can cut them down as far as you want but there are somethings to consider.
One, you want something in between the a-arm and the bumpstop, metial to metal is bad. If you are going to reduce the amount of the soft rubber, I would just buy some polyurethane shortie replacements. You can find them at any off road shop, they are very common.
I have the low pro stops on my truck (compression only because I run ball joint spacers) and am considering reinstalling the stock bumpstops. Those thicker stock ones are part of the suspension and they have the effect of increasing the spring rate when the suspension reaches the end of the line. That is good and helps to prevent damage.
If you are looking for more travel one option is a product we make called ball joint spacers. You can see what they look like on our site www.sdori.com and purchase them from the vendors on our home page along with other things.
Frank
Old Nov 10, 2007 | 12:13 PM
algranger's Avatar
perfect!! i ordered a rear 2" shackle lift today to get me by until i do the sas. the spacers will go perfect with that. thanks
punks_is_4x4
May 31, 2016 06:03 AM
Shaun Crystal Gomban
Sep 20, 2015 11:16 PM
Patrick1976
Sep 15, 2015 11:33 PM
ErikZ1220
Sep 10, 2015 04:53 AM
