Door panel swap
Old Nov 19, 2007 | 08:22 PM
Green93's Avatar
Door panel swap
I have been searching but haven't found a definite answer. I want to upgrade my interior with power windows/locks/mirrors. It seems way easier to find a runner with a loaded interior than a truck. Will the door panel or a 4 runner work on my x-cab truck? What about the power windows and mirrors? The place local to me seems to have runner after runner but no trucks.
Thanks for any help,
Jason
Old Nov 19, 2007 | 08:55 PM
Jay351's Avatar
It might be easier just to swap doors.
Old Nov 19, 2007 | 08:58 PM
Elton's Avatar
should work
Old Nov 19, 2007 | 09:46 PM
Green93's Avatar
That might work, but then I'd need to find the right color. It would be worth it though. Those 4 runner panels are way nicer than my vinyl ones.
Jason
Old Nov 19, 2007 | 10:09 PM
Jay351's Avatar
Jason
I have the sr5 cloth panels
Well, you do have some body damage, to fix it right you will need paint.....
Old Nov 20, 2007 | 06:38 AM
aviator's Avatar
You can swap the inner door skins (panels) no problem this is what I did. However you must use the skins from a two door runner, the front doors on the 4door are shorter also you will most likely have to make a custom harness for the power goodie wiring since it almost definitely won't be there. Not to bad a job but a major PITA.
as another option you could just wrap the vinyl skins with fabric and customize them yourself. for the power goodies there are aftermarket options.
Old Nov 20, 2007 | 07:00 AM
fastkevman's Avatar
Originally Posted by aviator
You can swap the inner door skins (panels) no problem this is what I did. However you must use the skins from a two door runner, the front doors on the 4door are shorter.
Good info but.....I don't know about everyone else but, I rarely see a two-door 2nd gen runner, let alone one I can strip for parts!
Old Nov 20, 2007 | 08:31 AM
Jay351's Avatar
There is one in the local import yard. Aswell as a canadian edition 1st gen runner that looks fixable
Old Nov 20, 2007 | 04:02 PM
Green93's Avatar
There is a 2 door runner in the complex here....but I don't think he would be too happy if his door panels were gone. Jay...is there a 2 door at alpis?
Thanks for all info.
Jason
Old Nov 20, 2007 | 04:13 PM
Jay351's Avatar
Pretty sure I saw one in new arrivals a little while ago. Im sure they have at least one, they are huge!
Old Nov 20, 2007 | 06:45 PM
90inworks's Avatar
there is one that drives by school in the mornings that just got wrecked lol if i see it stop being drove ill see what i can do for the panels if you would like?
Old Nov 20, 2007 | 07:11 PM
Green93's Avatar
Do you know what color the interior is? It would have to be an SR5 though since my door panels are in great shape...just want to upgrade.
Jason
Old Nov 20, 2007 | 07:19 PM
90inworks's Avatar
um im not sure the runner is the light blue color if that helps?
Old Nov 20, 2007 | 08:00 PM
DeathCougar's Avatar
Originally Posted by Elton
should work
*buzzz* Wrong.
I know aviator already stated, but the 4runner doors are shorter than the truck doors, thus the panels will not work.
Find an SR5 Truck, or a 2 door 4runner, and swap all the guts from them.
Old Nov 20, 2007 | 09:00 PM
Green93's Avatar
Thanks Deathcougar.
And just to beat this topic to death....would the internals matter if they are from a 4 runner? I'll be upgrading to power windows and not sure of the extent of parts I have to swap out.
Thanks
Old Nov 20, 2007 | 09:58 PM
if the internals were from a 4 dr, yes it will matter. The 2door internals should be the same though. the internals (wiring etc) from a 4 door 4runner are obviously set up for 4 power windows, and also power mirrors and locks.
Old Nov 21, 2007 | 05:54 AM
aviator's Avatar
The motors and actuators are all the same so no problem the window regulator is different, and the driver's side switches for the window/locks are different. The mirror control switch is the same. The pax door switches are the same but the plate they are mounted in is different (slightly shorter i think but I've never measured it). The mirrors themselves use the same mount but are a different shape so you'd need to get a pair of them.
Old Nov 21, 2007 | 05:58 AM
isaac338's Avatar
getting controls from a 4 door runner sucks because you'll have four window switches, but a pickup only has two windows. i didn't think of that till i got all the parts home
Old Nov 21, 2007 | 03:40 PM
Green93's Avatar
Haha, ya I thought of that. Would drive me crazy seeing those extra buttons.
Old Nov 22, 2007 | 08:29 AM
aviator's Avatar
you could wire up the extra switches for other purposes... power tail gate anyone?... air suspension controls?... aftermarket power sunroof controls?...
pax. ejection seat?... machine guns?... oil spray?... garage door controller?...
Use your imagination...
maybe macguyver the power rear window motors from a Chrysler mini van in to control the xtra cab rear windows?
