PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 [95] 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. 87 22R carb issue? Bad idle
  2. 94 pickup 22RE Overheating
  3. VF1A t-case & R150F shifter gasket?
  4. rebuilding 22re need opinions please
  5. TG Rear Disc Brake Kit at Davez Off Road Performance
  6. irab88's '93 SR5 conversion thread
  7. clutch line removal,help!!!!!!!
  8. Sas 4runner clunks when braking
  9. My Awesome 4runner
  10. turning brand new brake rotors?
  11. Head gasket and timing belt replacement....
  12. Need help with turn signal issue
  13. 95 4runner V6: 7 inches of lift and 36x15.50's can it work?
  14. Are there any solid bumpers that'll fit around stock carrier?
  15. 88 3VZE has no power
  16. 2.5" or 3" lift kit
  17. Factory Stripe Kit
  18. Wideband O2 sensor/gauge ... worth it??
  19. Enhancing 4runner power mpg
  20. R154/R150F Hybrid Question
  21. How many of y'all don't have rear bumpstops?
  22. cold starting issues...
  23. mods to improve mileage?
  24. 86 Tranny drain plug washer?
  25. Should I change out my steering damper while I'm in here?
  26. options to get rid of the dash??
  27. O2 sensor grommet
  28. thermostat weep hole leak
  29. 90 4 runner 340h tranny wont shift
  30. when did Toyota change the main fuse box mount?
  31. 1990 22re front brakes did i pay to much?
  32. EFI part question
  33. Upgraded to 35's what IFS components should I upgrade?
  34. U BOLTS with SHOCK MOUNT
  35. Hello
  36. Power Window Issues
  37. What is this 3VZE noise?
  38. Good Replacement Radiator?
  39. rebuild warrantee question
  40. emergency steering question
  41. Charging issues
  42. Leaky fuel injectors
  43. Few assorted questions, help would be great.
  44. BAD clutch squealing
  45. 3.0 Valve Covers
  46. Track-n-Go
  47. Fender Bender :(
  48. 86 tranny oil capacity?
  49. window tint
  50. Quick cv axle question
  51. 22re clutch slipping after lo-lo-4wd
  52. 90 4runner vibration squealing while driving
  53. 1st gen 4runner: Help in wiring rear cargo switch for rear window
  54. Knocking noise in 94 4rnr 3.0
  55. 1st Gen 4Runner: LED Glove Box Light Mod
  56. ATK Motor 22RE
  57. Speedometer cable replacement tip
  58. Finally got me a truck!
  59. 88 22R block crack
  60. been a while/summer plans
  61. 90 SR5 to 97 4Runner e-locker Axle Swap
  62. 95 sr5 v6 broken front diff? HELP
  63. 94 4 runner dull buzzing in the dash?
  64. could this be a cracked exhaust manifold?
  65. 3.0 Toyota Pickup Gauges Don't Work When Below Freezing
  66. Preventative replacement of head gasket?
  67. 3VZE Erradic idle and jumping tachometer
  68. rear window question
  69. Bad bushings on leaf springs and shackle on 88 4unner?
  70. Can anyone identify this connector?
  71. RF1A problem
  72. 4runner just died going down interstate....
  73. Oil Leaks
  74. 5.29s and 32s-how high (RPM) is too high?
  75. replacement stock ride coil replacement
  76. New 1 Ton Dually Yota - Interchangabilty of parts?
  77. 22R-E bucking/jerking only on highway under load, only symptom
  78. 94 Toyota pickupsr5 4x4 Right signal will not work left signal is fine NEED HELP!!!!!
  79. put engine bak together after sitting for a year
  80. Timing cover removal write-up
  81. Fan pulley bracket aka water pump thing
  82. Tranny fluid through the shifter?
  83. Getting Desperate - backfire/popping from intake
  84. 22 RE air intake relocation idea; advice needed
  85. Trying to retrieve MIL code... all I get is blinking cruise light
  86. 22re start problems
  87. v6 low compression mechanic says I need new motor. HELP
  88. anything else i should check or be the problem?
  89. Went through some deep water now power brakes dont work?
  90. Diff interchange questions!!
  91. Suggestions for broken window?
  92. v-6 lockright in factory 4:88
  93. 3VZE PCV Valve
  94. Original hood back on
  95. Resonance/humming from behind dash in 5th gear, changes with RPM (22re)
  96. Starting my auto to 5 speed mod
  97. Oil change question.
  98. Alternator
  99. 87 4runner uhaul tow hitch fitment issues
  100. On-car injector cleaning for 1988 22RE
  101. 22RE high idle problem.
  102. Noisy 3rd.
  103. 86 wiper lever repair??
  104. Headers installed, need help with blocking heat
  105. 3.0 auto stumble from dead stop
  106. Loud howling at around 55???
  107. 22R '86 Pickup Hiccup - A cure?
  108. Landcruiser Coils Questions
  109. 91 v6 idles 400-900, taking off it bogs then jumps into power
  110. 1987 Toyota Turbo Truck rust inspection
  111. Tie rod ends from Autozone-Oreilys-Advanced
  112. Factory air box question - 22RE
  113. Timing belt stalling issues
  114. HELP! No headlights after harness upgrade
  115. 85 supra afm refurb
  116. Anti-Theft cover for Aisin Locking Hub?
  117. Junkyard A/C upgrade question
  118. 22r timing question
  119. Vaccuum canister 90 4runner in passenger fender well ?
  120. 22RE problems. Where do I start?
  121. 22re knocking
  122. 1991 V6 4-runner won't start
  123. 94 fuel pump change out
  124. 1993 Toyota Pickup 22RE Exhaust?
  125. running rough idle
  126. 22re shortblock into a 83 pickup, no efi?
  127. 3.0 power loss
  128. Front Locked up doing 65mph
  129. A/C and Speedometer help
  130. Cd player mounting hole not the same as stock?
  131. What size bumpstop to use with OME springs?
  132. boil over and bearing noise. Water pump failure?
  133. 93 4runner figured out performance issue
  134. Fuel line woes
  135. Transmission Gear Ratio
  136. brass spindle bushings or spindle bearings?
  137. pickup 22r ignition
  138. weird head gasket failure on 3vze
  139. 93 Toyota Tailgate lock striker
  140. Zuk Mod Problem?
  141. Bypassing the secondary O2
  142. Timing belt issue 95 4runner
  143. Non-matching body lift
  144. 4runner sr5 cluster swap into pickup questions
  145. 22RE fuel injectors
  146. Need help finding 3.0 V6 motor
  147. 93 4Runner V6 Auto 4x4 speed sensor road block
  148. Idle sticking at 1500 RPM
  149. TIMING is way off!! PLZ HLP
  150. Weird tranny/T-case situation
  151. LSPV and Rear ABS info
  152. Interior singlecab dimensions for fatmat?
  153. White powder/corrosion engine bay
  154. Coolant Leak @ Air Pump
  155. 1st Gen 4Runner: Under dash courtesy light?
  156. Ammocan cup holder build
  157. 95 4runner - 4x4 6ylinder automatic - O/d Doesnt Work - Plus More
  158. '95 v6 engine issues
  159. differential swapping?
  160. CA. SMOG TEST FAILURE! Help from Smog Techs/other Guru's???I'll post my convo with th
  161. im lost..!!!!!
  162. Fuel pump relay, DS dash - but why?
  163. Exhaust Leak at Flange
  164. ZUK mod question - Uneven leafs
  165. tips to change head gasket on 22re
  166. 87 4runner Blown Head Gasket
  167. Need knock sensor (3VZ-E). What kind?
  168. Cam Shaft Sprocket Mis-Alighment...HELP!!!
  169. Advice for Hydro locked 3.slow
  170. Exhaust gaskets??
  171. Looking at getting 2 inch body lift. Need pointers/best vendor?
  172. Simple leafspring question
  173. 22re ECU Year
  174. My '94 is dead, long live my '12!
  175. Engine cutting out power loss.
  176. 5 speed reverse light switch
  177. Got a brand new 1987
  178. Idle Pulse when A/C is on... 22RE
  179. losing coolant
  180. IAC Gasket Question
  181. new VIDEO: cheap truck challenge with a '80 Yota 4x4
  182. 86 pickup motor swap
  183. 1st Gen 4Runner: Factory Double stack console?
  184. converting rear slide window to electric
  185. 87 4runner previous owner electrical nightmare
  186. Help replacing the window regulator?
  187. 86 4runner frame swap help
  188. 93 Engine Rebuild, Won't Start, Maybe O2 Sensor?
  189. Getting Rid of the Lift, and its a rust bucket?
  190. IFS front diff upgrade?
  191. Rislone head gasket fix
  192. 3VZE oil pump, oil pan tricks and tips?
  193. torque specs
  194. Hard to start when engine is cold
  195. Looking for a v6 rear carrier for 89 runner
  196. Help Diagnosis 3vze Engine Knock
  197. Truck stalls out after 30 Secs!!!
  198. abs sensor removal..help!!!!
  199. 94 V6 engine problem. HELP
  200. back window replacment?
  201. Toyota 'Buzzer'
  202. 3vze automatic to 5 speed swap
  203. radiator flush on 95 t100 sr5
  204. Rear window now works but why?
  205. Took the dive.... 94 4Runner 3.0 auto. lift q's
  206. Pretty Urgent: How to put on RED FIPG on a W56?
  207. What could it be? :(
  208. 3.83 Gears?
  209. Part Number and/or proper name for P/S drive pulley?
  210. Wont start 88 4runner
  211. I got diagnostic code 41
  212. My Slow, budget friendly Build/ Restoration!
  213. the time has come to redo or try and repair my roll on paint job.
  214. Window wont roll down any DIY?
  215. Bad swap
  216. 87 22re cold start fine stumbles when warm then fine
  217. 22re oil in cooling system only
  218. 2nd Gen 22re 5spd real world MPG's stock
  219. Newbie needing input! O2 & fule filter related(I think)
  220. 87 SR5 gauge panel in 86 Toy camper
  221. rear washer plug - 93 4runner
  222. Brake Booster Anyone?
  223. no start after reinstall of steering coloum
  224. Need wood grain bezel for 1999 4R limited
  225. 1990 4wd v6 engine problem
  226. old man emu
  227. too much weight hanging off the front frame rails?
  228. 22RE overheats when HVAC is on heat
  229. 94 pickup 4x4 w/22RE Missing/Stumbling
  230. 3.0 HG question, low compression, runs fine??
  231. Brake Booster Electrical
  232. W56 Noise (HQ Audio)
  233. 2.5" ball joint spacers(need new shocks)
  234. Truck will start but quickly stalls..whats the problem?
  235. blown head gaskets on my 3.0 need sujestions ?
  236. Are my vacuum hoses set up wrong?
  237. Random popping noise when steering at full lock
  238. Transmission Converter Lockup Issue When Cold
  239. Weird Overheating problem after HG job 95 3VZ
  240. wiring problem
  241. Just bought this 93 extra cab
  242. 2nd gen 4Runner rear tailgate wiring problem
  243. Diamond in the rough?????
  244. pass door won't open on a 1994 pickup
  245. identify these high steer arms
  246. Going to buy a 94 yota
  247. noisy Zuk mod?
  248. VSV question
  249. Another 22RE weird idle thread
  250. Body mount "PROBLEM"
