Trying to retrieve MIL code... all I get is blinking cruise light
Old Apr 25, 2012 | 05:45 PM
easy-3vze's Avatar
As title says...
I am trying to diagnose why my Rear anti-lock light is on.
First thing the manual says is to check the code being thrown.
I hook up my paper clip as indicated. Turn ignition on and all i get is a rapidly flashing cruise control light. At a steady pace with no change. ie: it's not a code it's just steady blinking.
wtf? this has worked on all previous toyota trucks i've owned.
Any idea on what's causing this issue?
Much appreciated.
Old Apr 25, 2012 | 06:36 PM
Stuwy123's Avatar
paperclip in the wrong spot?
Old Apr 26, 2012 | 08:11 AM
easy-3vze's Avatar
Tc and E1 as the manual suggests.
Double and triple checked.
Old Apr 26, 2012 | 08:43 AM
Stuwy123's Avatar
Neat.
It's supposed to be TE and E1.
Service Manual, engine diagnostics section. Even shows you a diagram.
http://personal.utulsa.edu/~nathan-b...26diagnosi.pdf
Old Apr 26, 2012 | 09:25 AM
easy-3vze's Avatar
Originally Posted by Stuwy123
Neat.
http://dl.dropbox.com/u/17699049/diagnosi.pdf
Thanks though.
Old Apr 26, 2012 | 09:31 AM
scope103's Avatar
That's what I love about Yotatech. An almost right question gets an almost right answer.
The MIL (Malfunction indicator light) is read with TE and E1 (Stuwy123). But that doesn't tell you anything about the braking system! (That is why the OD light is flashing, because TE-E1 also triggers the transmission diagnostics.)
To find a problem with the braking system, you DON'T want the MIL, instead you go Tc and E1 (easy-3VE). That flashes the Rear Anti-Lock light.
So you got the wrong connectors with your SST (Stuwy123, but not for the reason given).
Old Apr 26, 2012 | 09:40 AM
easy-3vze's Avatar
Make sense, I see how I was referring to the wrong indicator/light now. Sorry about that. To be honest, it was hard to know which light was being referred to because it just says "the warning light." Since none of them seemed to be blinking as indicated by the manual i just assumed it was suppose to be the MIL light coming on. My mistake. I will go have another look after work.
Old Nov 25, 2012 | 06:58 AM
SR586's Avatar
Any luck figuring out how to get the rear anti lock light to show the code?? I jumped Tc and E1 and nothing happens with the rear anti lock light.
Edit: 1992 Toyota 4Runner 3vz w/ R150F 5 speed transmission SR5
rusty904
Mar 27, 2017 05:20 PM
shisha1999
Sep 21, 2015 08:22 PM
AkitaDog
Sep 1, 2015 08:05 AM
256mbaker
Jul 31, 2015 06:45 PM
jake_v
Jul 22, 2015 03:17 PM
