'95 v6 engine issues
Old Apr 18, 2012 | 05:30 PM
gooseman1's Avatar
I have a 95 4runner with the v6 engine. I just completed a bunch of maintenance, timing belt, water pump, plugs and wires and a few other lesser things. The truck runs fantastic with one exception...
When the throttle is released I get a check engine light that comes on for 1/2 a second, the engine also seems to lose power for that time. If it's at idle and I just rev the throttle and let it go, sometimes the engine will cut out all together. Like I said, otherwise the thing runs much better than before.
BTW, this problem ocurrs at any RPM, driving or in neutral.
What am I missing?
Thanks!
Old Apr 18, 2012 | 05:55 PM
nv4runner's Avatar
Sounds like you need to test and/or adjust your throttle position sensor. There are multiple threads with links to the factory service manual that has the procedure and specs that you'll need. Definitely test it first because it's a pricy sensor.
Old Apr 19, 2012 | 06:33 AM
Team420's Avatar
X 2 on the T.P.S., also check for vacuum leaks.
Old Apr 19, 2012 | 07:00 AM
scope103's Avatar
Originally Posted by gooseman1
When the throttle is released I get a check engine light that comes on for 1/2 a second, ...
Did you check for (stored) codes? If you get a momentary CEL, you probably have a stored code, which you can retrieve in the usual way with a paperclip. That will give you a good hint for where to start looking.
Old Apr 19, 2012 | 03:04 PM
gooseman1's Avatar
The TPS adjustment did it guys, runs like a top.
THANKS!
bigjstang
Jun 2, 2025 03:56 PM
snosurfer
3.4 Swaps
Aug 15, 2024 02:11 AM
icentropy
Sep 16, 2020 02:47 PM
smiley52
Jul 11, 2015 05:16 AM
nick b
Jul 11, 2015 04:38 AM
