94 V6 engine problem. HELP
Old Apr 15, 2012 | 11:46 AM
94Beater's Avatar
I have a 94 excab 4x4. I was turning around in the road the other day and she just died never to crank back up! Had a friend come pull me in and it will start being pulled but it will not idle and it runs very rough! I have since changed the fuel filter plugs and wires. It will sometimes diesel after trying to start also. I am getting fire out of the coil but nothin from 3 of the plugs.( i stopped checking after 3) dist cap and rotor look ok. Any help??? Thanks!!
Old Apr 15, 2012 | 04:17 PM
vasinvictor's Avatar
Pull the front timing cover and check the timing marks line up. Possible jumped a tooth or two. Hydraulic/spring tensioner could be getting weak. Check your fuel pressure too.
Old Apr 15, 2012 | 07:10 PM
TNRabbit's Avatar
Check for engine codes FIRST.
Then go from there.
Old Apr 15, 2012 | 07:12 PM
Then go from there.
Yeah I got excited. Do this first before you go ripping the engine apart.
Old Apr 15, 2012 | 07:56 PM
94Beater's Avatar
I have no check engine light on can you still check codes?
Old Apr 15, 2012 | 08:05 PM
Yes- quick search should show you how. Post back once complete.
Old Apr 15, 2012 | 08:58 PM
scope103's Avatar
Originally Posted by 94Beater
it will start being pulled but it will not idle and it runs very rough! ... . I am getting fire out of the coil but nothin from 3 of the plugs.( i stopped checking after 3) dist cap and rotor look ok.
How can it run at all if none of the spark plugs are firing?
I assume you pulled the coil-distributor wire and got a spark to ground when cranking. I assume you did the same thing to three plug wires (or plugs), but got NO spark. I would do the same to the other three; if you have 3 plugs firing that could be enough to get it to start and run rough (really rough).
Then if 1/2 of your plugs are firing, the problem is in the plug wires or the distributor.
This will probably throw a code (checking for codes is always something you need to do, and it's easy), but if you can narrow the problem down to WHERE it is you're almost home.
(Incidentally, a jumped tooth on the timing belt will have nothing to do with a "no spark" situation.)
Old Apr 18, 2012 | 04:33 PM
94Beater's Avatar
Yeah i did app something is firing but the 3 i checked werent. How do you check engine codes?
Old Apr 18, 2012 | 05:54 PM
TNRabbit's Avatar
This question gets asked and answered 10 times per day AT LEAST. PLEASE FOR THE LOVE OF GOD READ THE FOLLOWING THREAD so we can avoid answering the same questions a bazillion times:
https://www.yotatech.com/forums/f116...k-3vze-187741/
Old Apr 18, 2012 | 08:43 PM
94Beater's Avatar
Great thread but i didnt see a thing about how to check engine codes
Old Apr 18, 2012 | 09:42 PM
TNRabbit's Avatar
Actually, post #20 contains a link to a ToyotaNation thread ( http://www.toyotanation.com/forum/80...e-posting.html ) . Post #2 in that thread gives a detailed account of how to check codes & what each number means.
Old Apr 19, 2012 | 04:50 AM
Team420's Avatar
if your getting spark to the dizzy, but not to the plugs, I would think that either A) plugs and wires are junk, B) rotor and cap are junk, or C) the dizzy is toast.
Old Apr 19, 2012 | 07:04 AM
scope103's Avatar
Oh fer crying out loud ... You don't have to make him jump through hoops.
http://www.ncttora.com/fsm/1990-1995...e/diagnosi.pdf
(The SST (special service tool) can be found here: http://www.officedepot.com/a/product...aper-Clips-No/)
Old Apr 19, 2012 | 01:00 PM
Gmparker13's Avatar
Randomly dying
My 1995 4runner would die randomly also and i ended up replacing the EGR valve and that fixed it.
Old Apr 20, 2012 | 12:10 PM
94Beater's Avatar
Thanks alot! That was much easier!
Old Apr 21, 2012 | 07:50 AM
imbatman19's Avatar
Sounds to me like the distributor. Codes? Good luck with this one.
Old Apr 22, 2012 | 12:36 PM
94Beater's Avatar
Well guess i was wrong i do have spark and fuel. Im clueless at this point!
Old Apr 22, 2012 | 01:00 PM
Did you ever check your codes like we suggested?
Old Apr 22, 2012 | 07:11 PM
94Beater's Avatar
Guess my check engine bulb is out. Goin to look into that tomorrow
icentropy
Sep 16, 2020 02:47 PM
rushw
Jul 18, 2015 01:46 PM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
colinmil
Jul 6, 2015 04:03 PM
Jnkml
Jul 6, 2015 01:20 PM
