Random popping noise when steering at full lock
Old Apr 12, 2012 | 11:06 AM
InternetRoadkill's Avatar
Question Random popping noise when steering at full lock
I know what you're going to say: Grease the steering stops. But no. That's not it.
The problem occurs at and near full lock when turning right. You don't have to be against the stops for the noise to occur. Just near full lock. (I already greased the stops, btw. Also, the hubs are unlocked.) The popping noise is severe enough you can feel it in the floorboard with your feet. It sounds like something is binding up then snapping free. This has me stumped.
(FYI, pretty much the entire drive line, suspension, and steering is new (<10K miles).
Just a wild thought, but I wonder if it's the detroit locker in the back binding up and transmitting noise down the drive shaft (???).
Old Apr 12, 2012 | 01:26 PM
dipasqualet44's Avatar
mine does the same thing same as my old two trucks i had also my buddys t100 and his 94 pickup i dont know i think it it just a Toyota thing
Old Apr 12, 2012 | 01:37 PM
toyotanick's Avatar
could it maybe be body flex? when you turn the wheel the frame twists a little causing the body to eventually let go from the spot it was in resulting in the feeling you are having?
maybe check the control arms make sure they are tight?
Old Apr 12, 2012 | 03:06 PM
Well, I crawled underneath and gave the u-joints a healthy dose of fresh grease. I also discovered there's more than 1 set of steering stops. I knew about the rear ones, but overlooked the front ones. I greased them all this time. Tomorrow, I'm going to check the rear diff oil level. We'll see what happens.
Old Apr 12, 2012 | 06:13 PM
i think it has something to do with the t bar system toyota uses every pickup t100 4runner etc does it at some point
Old Apr 13, 2012 | 06:05 AM
The torsion bars and suspension bushings are all new.
Old Apr 13, 2012 | 07:24 AM
what im saying that i think its the way toyota set up the torsion bars
Old Apr 13, 2012 | 12:30 PM
TNRabbit's Avatar
Could be a cv joint going....
Are you certain it's not in 4 wheel drive?
Do you have a locking hubs?
Old Apr 14, 2012 | 08:06 PM
KRos_+'s Avatar
Upper balljoints lubed and tight>??
I get a the same thing. But my Bjs were shot! And i mean shot to Sh**! lol
Old Apr 14, 2012 | 08:22 PM
Kiroshu's Avatar
Outer CV axle joint. (Click or pop) on turns. Usually rapid sounding.
Steering Stops + Lithium Grease = Quite time.
Old Apr 1, 2014 | 04:32 PM
sphealy's Avatar
Was this ever fixed I'm having same issue.
Jun 1, 2021 01:51 PM
mskalmus
May 28, 2017 07:51 AM
coreyedwards7611
Jan 16, 2016 06:38 PM
88runnergomas
Jul 9, 2015 01:12 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
