22RE high idle problem.
Old Apr 24, 2012 | 09:32 AM
Snauty's Avatar
Okay, So i just rebuilt my 22re and when i first started it, i had to turn the idle up becuase it was really low and surging. Fired it up and it was all good. I drove it around for a couple days, and it was running fine. Then i got home one day and the idle shot up from factory 750 to about 1500 and wouldnt go down. So i turned the idle down back to 750, and drove it around for the rest of the day and it was fine. Until i got back home again and it was surging, like to low of idle. So once again i turned the idle back up to where i had it origionally at 750. Now it shot back up to 1500 and running to high.
My question is, Did i forget to hook somthing up during the installation or does this sound like an airleak?
I already checked the throttle plate, and its not sticking. Im kind of lost here.
Old Apr 24, 2012 | 09:42 AM
Black_1985_SR5's Avatar
Did you adjust the tps? also how did you adjust the idle?
Old Apr 24, 2012 | 05:56 PM
Snauty's Avatar
I adjusted the idle with the idle set screw.
Old Apr 26, 2012 | 11:15 AM
Bad Karma's Avatar
Check the o-ring on the idle screw. If it's worn out, the screw will vibrate and spin up or down (mine did both).
redneck17
Oct 29, 2015 09:09 PM
luckypig44
Jul 19, 2015 11:25 AM
ZONAYODA
Jul 13, 2015 07:17 PM
Nickdigg
Jul 7, 2015 06:04 AM
Jnkml
Jul 6, 2015 01:20 PM
