v6 low compression mechanic says I need new motor. HELP
Old 04-25-2012, 11:46 AM
khanman47's Avatar
My mechanic said the previous owner had used a sealant in the radiator and now the compression is low, he says I'm going to need a new engine, I'm not the most mechanically inclined and hes quoting me at 3800$ for parts and labor. Does any of this sound right?
Old 04-25-2012, 11:48 AM
westjohns yota's Avatar
what kind of motor? whats it in? a little more info about it would be nice?
Old 04-25-2012, 11:56 AM
waskillywabbit's Avatar
A 3.crap I assume from "V6" and this section.
For that kind of money do a 3.4 swap.
:wabbit2:
Old 04-25-2012, 12:20 PM
khanman47's Avatar
It's a 3.0 3vz and the mechanic said the last guy used a sealant in the radiator and that the compression is bad is some cylinder (he a trusted mechanic) so he says I need to replace the engine. How long do you think this engine will last? Im very short on cash atm so idk
Old 04-25-2012, 08:17 PM
prob not long, if you need a replacement dont do the 3800, either buy a replacement motor from a junk yard and swap it yourself (if you can) or send it to wabbit and do a 3.4 swap, better motor, better performance, better mpgs
Old 04-25-2012, 09:47 PM
khanman47's Avatar
Well is the wabbit in alabama no way I can get my tuck there for cheap I live in Cali, Anyway I can swap it myself?
Old 04-26-2012, 12:03 AM
TNRabbit's Avatar
Originally Posted by khanman47
.....I'm not the most mechanically inclined....
....Anyway I can swap it myself?
I'd call a NO on that~
Old 04-26-2012, 07:17 AM
khanman47's Avatar
Well with the help of my dad whos swapped before I don't think it will be too hard.
Is there anything special needed or is it just a donor car and swap it over?
Also what type of tools would I need.
Old 04-26-2012, 08:04 AM
TNRabbit's Avatar
There are several threads here about the swap in great detail. There is some harness splicing & several odds & ends you need to know beforehand. You can find all the 3.4 swaps here:
https://www.yotatech.com/forums/f160/
Sleaker
08-26-2020 06:03 AM
montanatruck
02-26-2017 07:07 AM
RatOmeter
10-22-2015 03:17 PM
thefishguy77
07-30-2015 10:59 AM
AaronM
07-08-2015 07:15 PM
Quick Reply: v6 low compression mechanic says I need new motor. HELP
