86 pickup motor swap
Old 04-16-2012, 03:28 PM
Bigg Ant's Avatar
I swapped out a motor from my 86 p/u and dropped in a motor from a 89. I had an issue with the injectors not working correctly. The truck had a 22r-t ecu in it(truck was once a turbo). Found an issue within the wiring but not before it shorted out the 22rt ecu and the 22re ecu. Do I look for the same exact ecu from the 89 to run my truck or an 86 22re ecu?
Old 04-17-2012, 01:17 AM
Staff
Terrys87's Avatar
You will need the 86 ECU, need to go with 86 injectors. Not sure about if you need a ECU that was turbo or not. Here is a link to the different injectors....https://www.yotatech.com/forums/f116...ectors-127606/
The 86 and 89 harnesses are different, one of the biggest is the diagnostic port.
Old 04-17-2012, 02:17 PM
Bigg Ant's Avatar
I have the 86 injectors in it.....seen the plugs were different from the 89. I'll look for a 86 ecu and see what happens.
vasinvictor
01-20-2016 12:39 PM
rondogracing
25
12-11-2015 07:26 AM
streetuner15
06-18-2015 10:59 PM
infinityisfive
06-16-2015 06:51 PM
ryangs
11-15-2002 07:50 PM
Quick Reply: 86 pickup motor swap
