22RE fuel injectors
Old Apr 20, 2012 | 11:50 AM
my 75 toyota's Avatar
Smile 22RE fuel injectors
Ok so i got a 88 pickup truck with a 22rec. The injectors in it are black with a thin red plastic shim in them.It seems 88 is the only years to use these. And since i am rebuilding it and going with a performance rv cam. Do i have to use these or are there a better performance injectors. I already have intake and a header for better performance just need to know what other injectors will work. Thanks
Old Apr 20, 2012 | 12:57 PM
Buck87's Avatar
I dont know if there are better ones out there, but if you stay stock like I did on my very similar set up, then you should get new ones or have those refurbished.
Old Apr 20, 2012 | 02:17 PM
Hadmatt54's Avatar
If you decide to upgrade your injectors, check the impedence. 88 model year was a transition year for the 22re. Early 88 were low impedence injector with a solenoid resistor built into the body harness, later 88 were high impedence injectors without the solenoid resistor.
Doug4320
Mar 24, 2018 10:11 PM
raptor510
Feb 17, 2017 07:11 AM
steve miller
Oct 10, 2015 01:40 AM
pyramid
Jul 30, 2015 10:05 AM
HookahRoo
Jul 20, 2015 07:06 PM
