Fuel line woes
Old Apr 21, 2012 | 02:21 PM
islanderoffroad's Avatar
Fuel line woes
Replaced my fuel pump and fuel pump bracket today. The pipe coming out of the bracket for the fuel line was pinched and seemed like it was probably contributing to my no fuel problem. when I went to unscrew that pipe from the fuel line, it broke
Now I've got everything in but I'm having a hell of a time getting that piece of broken pipe unscrewed from the flex line. It was already rounded off before I got to it. Used a 14mm flare wrench, no luck. Used lots of PB Blaster, vice grips, everything I had and could think of. Obviously not going to use a torch due to the proximity to fuel.
I even tried taking off the flex line on the frame end and figured I'd just replace that piece, but the second I started trying to turn a wrench on it, I saw it was just gonna twist the fuel line on the frame.
Any ideas? I'm frustrated... I've owned this truck a month now and its spent more time not running than running. At this point I'm ready to just fix it and sell it before it gives me another problem.
Old Apr 21, 2012 | 03:57 PM
slacker's Avatar
so .. I'm assuming you have dropped the tank out of the truck or 4Runner , correct ?
I woulnt waste much time trying to save it , use a pipe cutter and cut it off .. then re flare it with a new/used nut in place
Old Apr 21, 2012 | 04:02 PM
No, tank has not been dropped, went through the access hatch under the rear seat.
I know I'm not saving it, the issue is getting it apart period so I can re-use the flex line.
Old Apr 21, 2012 | 04:03 PM
slacker's Avatar
ahhh 4 runner , I would drop the tank ..
Old Apr 21, 2012 | 04:23 PM
I don't see what dropping the tank has to do with my current problem.
Old Apr 21, 2012 | 04:28 PM
slacker's Avatar
really ? .. gives u a whole lot more room to work on things .. and do it right instead of mickey mousing it
Old Apr 21, 2012 | 04:34 PM
Space is not the issue... other than the fact that I can't get a bench vise in the back of the 4runner.
I need that apart. Dropping the tank won't make a difference.
Old Nov 5, 2012 | 09:58 AM
BearRunner's Avatar
Where did you get fuel pump bracket?
pyramid
Jul 30, 2015 10:05 AM
Poppie51
Jul 23, 2015 05:03 PM
Hiluxtrucha
Jul 22, 2015 10:00 AM
Poppie51
Jul 16, 2015 06:16 PM
Fundy Rider
Jul 16, 2015 01:35 AM
