3.0 power loss
Old Apr 21, 2012 | 11:09 PM
runs-on-4's Avatar
3.0 power loss
the past few days ive noticed my check engine light turns on. but now its mostly always on. ive noticed a noticable loss in power. but when it the lights off usually for a minute when i first start it it has plenty of power.
this ever happpen to anyone?
Old Apr 22, 2012 | 02:45 AM
iselloil's Avatar
check out my post.https://www.yotatech.com/forums/f116...-issue-252592/
Check for codes,and bad grounds.
Old Apr 22, 2012 | 08:38 AM
runs-on-4's Avatar
did your check engine light go on? and was it a consistant problem?
Old Apr 22, 2012 | 11:08 AM
humphreys1588's Avatar
had the same problem when I first got my runner. check engine would come on and it would run super rough. Ended up being the knock sensor. Might want to look into that....
Old Apr 22, 2012 | 11:33 AM
runs-on-4's Avatar
im looking into that and the o2 sensor. any idea how much a shop will charge to read the codes?
Old Apr 22, 2012 | 11:55 AM
iselloil's Avatar
You can scan it yourself with a paper clip.Jump the service connection by the fuse block under the hood. There is a tag that shows which pins to jump. Tnen turn the key on and count the short and long flashes on the dash.Search the post on how to do it.
Sleaker
Aug 26, 2020 06:03 AM
coleypull15
Nov 3, 2015 07:41 AM
tj884Rdlx
Aug 28, 2015 12:04 PM
93toyoguy
Aug 2, 2015 07:41 PM
tobylab
Jul 12, 2015 12:53 PM
