PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 [183] 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. Help Front Diff Problem
  2. timing chain hole in cover info needed
  3. going to buy k&n air cleaner for my 22r but...
  4. Squeeling!?
  5. What have you done to get extra power and /or MPG
  6. CV, Ball joint, TRE, replacement write up with PICTURES!!
  7. Sylvania Silverstars
  8. Burning oil
  9. heres my project..
  10. broken bolt on egr...
  11. best way to go about switching some parts..
  12. Where to set idle and timing on 22R?
  13. No spark
  14. if anyone wants a real cheap 3.4Lsc swap
  15. Check Engine Light not working
  16. Who has bucket seats...?
  17. air/fuel mixture screw setting
  18. Marlin Or InchWorm, Single or Dual Case?
  19. New Guy here
  20. 22RE Intake Allen Bolt
  21. brake reservoir
  22. Locals of Washington State!!!
  23. Hmmm 33's or 31's????
  24. Head Help!!!
  25. Engine Rebuild Help -22re
  26. Question regarding the center diff.
  27. Turbo???
  28. Napa Rear lift coils :) 69$
  29. 3.0 fuel Milage
  30. Welded front 3rd ?'s
  31. kumho road venture at kl78's
  32. Anyone want to sell me an ECU for an 86 4cyl Auto 4x4 22re?
  33. Cranking T-bars
  34. Converter lockup switch (for the auto guys)
  35. Chain to Gear Tranny swap
  36. is this a good price?
  37. well this sucks!!!
  38. taking cam bolts off - the solution
  39. steering goes bad after driving through water
  40. My Clutch will not fully disengage. Getting annoying.
  41. Turn Signal Relay Help!!!
  42. Is My Rear Diff Going Out?
  43. Downey grille guard/skid plate.
  44. Tacho question engine swap
  45. Can I swap an A340F for my A340H?
  46. mpg question
  47. Bad Alternator???
  48. 3VZE Ticking At Constant Throttle
  49. Computer question...
  50. Help tracking down a bad wire
  51. Quick question
  52. Brake booster replacement
  53. Body & Suspension lift question!
  54. 1991 22re pickup trouble
  55. are our trucks dieing ???
  56. fuel leak on fuel rail...
  57. Fuel Line Question
  58. Opinion on these shocks for a 4Runner
  59. CEL code 25 Need Help please.
  60. Auto Trans Noise
  61. R&R Rear Shocks-95 SR5
  62. How do you test the Tach?
  63. another newb-tire to gas mileage question
  64. buying my first, what does this mean?
  65. any fast 22re's?
  66. Can anyone tell me real quick .....
  67. Heater.
  68. oil ight on warm starts
  69. Sooo...
  70. Please Explain (not for me..for my "mechanic")
  71. Clutch will not fully disengage.. hElP...
  72. Which Winch Brand Is Best
  73. Anyone running the old Air Soft bb's in the tire trick...???
  74. the rebuild is up and running sorta....
  75. 1JZ turbo Supra motor and tranny in a 86 pickup
  76. 22R Front Crankshaft Seal Question
  77. 86 fuel leak help
  78. newb with an interior question...
  79. she's alive! SHE'S ALIVE!!!
  80. Can i borrow 900 bucks??
  81. Replaced cylinder head, now 22re runs rough
  82. How To: Replace Broken fuel injector connectors.
  83. Lockers or re-gear??
  84. Problems with Tach (SR5 cluster)
  85. Lifting- body or Suspenion
  86. How to check the gearing on 4x4 - 86 IFS 4cyl
  87. Lower Control Arms
  88. Broken climate control cable
  89. Can I override the auto trans OD temp sensor?
  90. A terrible tradgedy..
  91. Toolbox CB Mount..
  92. won't start
  93. Sorry for nagging caliper questions.
  94. Bad Clutch
  95. Somethings not right in my 22re HELP
  96. Weird Idle Problem
  97. Replacing 22re in my new 92 truck
  98. How To Rebuild A Caliper?
  99. Click and no bang!
  100. Alignment????
  101. TJM T-15 installed w/pics
  102. What Spring to choose
  103. What the heck?!?!
  104. Got problems. Need answers! 87' 4runner
  105. 3.0 v6 compression
  106. Brakes locked up - what to check?
  107. Rag Top
  108. sputtering at idle and while coasting only
  109. Truck plans!
  110. 20r head on 22r block? im confused!!!
  111. Power supply issue, or just random occurance?
  112. Got my truck back....not too pleased
  113. 86 Pickup wheel fitment
  114. Timing Chain help!
  115. Rebuild Question/advice
  116. few questions on wiring up tow dolly
  117. build halted by stupidity
  118. Looking for a Centerforce Clutch
  119. Adjusting a manual steering box from a 1994 4x2 pick up?
  120. Need an interior Part Dimension from a 1st Gen 4Runner
  121. ARB bumper dimensions
  122. water on top of valve=bad?
  123. Looking for a Off Road Light Bar
  124. Brake Calipers
  125. 88 4runner rear wheel well cut to fit 36/13.50?
  126. truck overcharging
  127. Help with cruise control
  128. Need opinions on a fuel tank swap.
  129. 90 4wd 3vze nasty vibration
  130. Clutch/trans problems
  131. Front locker (Which one?)
  132. Front end clinking/banging noise...
  133. 22RET tuning
  134. Removed head, pistons looking bad
  135. 22re main bearing questions
  136. Just want to get rid of the sag
  137. leaf springs
  138. roof rack questions
  139. swaybar end links
  140. What if my timing on the timing belt is completely off?
  141. What to look for before buying 89 runner?
  142. finally a positive note!
  143. 93 Axle in a 87 Pickup?
  144. Steering Stabilizer nut missing??
  145. 87 4Runner - clutch and reman engine
  146. Largest tire with IFS
  147. EGR Temperature Sensor Wires Disconnected
  148. Flex fan anyone?
  149. Auto Trans question
  150. Front Diff Leaking
  151. Quick Axle Question
  152. More broken IFS garbage
  153. ok time for a 3.4L
  154. Top dash
  155. Broke stuff!!
  156. torsion bars
  157. questions on JDM engines
  158. 1994 rear window issues???
  159. Locker Diferences ?.
  160. Whats involved inlift kit
  161. Front end noise, vibration
  162. 22re piston ring project
  163. Almost done and BAM... Water
  164. Engine stalls - what to check?
  165. brake anti-rattle springs...
  166. truck is coming together..
  167. Helpfull Tips on a new Exhaust from Block to rear bumper 1986 4runner auto 4cyl
  168. Is it my blower motor or resistors? 86 4Runner
  169. Should I balance my 22re?
  170. Anyone want/need a used exhaust for a 86 4runner, auto, 4 cyl (Southern California)
  171. Fuel pump problem. Experts help!
  172. Winch Bumper questions
  173. Exhaust Questions
  174. Scuba's Manual Hub Rebuild
  175. Rubicon??
  176. rear pinion question
  177. First wheeling experiance with MUD!
  178. Valve Adjustment
  179. Recently changed head gasket, sounds loud now
  180. My 22re is not running well
  181. 1 ton dually axle
  182. HELP; Need to bypass the Neutral safety switch
  183. 3.0 distributer
  184. Steering Knuckle Bearing
  185. No 4WD - need help diagnosing
  186. Timing a 22RE
  187. Shortshifter for the R151?
  188. replacing cv boot
  189. squeeaak...CLUNK! when turning
  190. First real trail run.....possible hydrolock? :(
  191. Grey transmission fluid
  192. Got stuck tonight:(
  193. 2door/2nd gen. NEW BFG/MTs, Detroit, 4.88s, 2" OME, Rola basket, spare carrier
  194. Im seing blue, LED that is
  195. 4runner worked out great
  196. Watching some video looking for 86's
  197. Painting my 4runner?
  198. 94 Toy V6 won't start w/o coolant?
  199. Are You Kidding Me!!!!????
  200. blinking od lite/wont engage 4th.
  201. 89 4Runner question
  202. Installing factory AC in my truck - Need help!
  203. Yay, new wheels!
  204. Evolution of the truck....
  205. Ball joint lift done, front end ?'s
  206. replacing interior?
  207. Ticking valve?
  208. Front Exhaust Removal - 3VZE
  209. My 4Runner Lift
  210. floor plugs?
  211. New rebuild wont start
  212. Newb Question
  213. I would like to see...
  214. 22re vs 3.slow
  215. EFI to carb swap
  216. Problem with part throttle...
  217. soft top done!!
  218. gasket replacing.
  219. truck wont run and pissing me off!!!!
  220. I need a 22R (carb) distributor
  221. holy crap this is getting old!!!
  222. Rising oil pressure?????
  223. Baffled...
  224. 22re, no heat, wierd heat spike while warming up.
  225. Bringing back 4WD letters on mudflaps
  226. air valve on my 4runner??????
  227. Probably needs a battery...what do you think?
  228. putting new engine back togather and have a quick question
  229. what do you think?
  230. Fuel gauge failing
  231. Power Steering?
  232. Manual Crank Window Problems
  233. Knock on startup, under load
  234. 1994 toyota pickup tires
  235. New tires, New discovery and a little mod
  236. Hella E-codes
  237. KYB shocks
  238. To paint wheels or not to paint wheels?
  239. 2nd Gen 4Runner makes noise at 50-60km
  240. Quick Exhaust question
  241. Help.. engine light. code 12 RPM
  242. Lift questions
  243. Speedometer BUZZING
  244. motor acting up
  245. locker for a 2wd 94 4runner
  246. Straight piped...engine damage?
  247. Name this Part!
  248. truck for sale
  249. Question On Head Gasket Replacement
  250. 86 4runner leafs on a 93 pickup
