Cranking T-bars
Old Oct 30, 2008 | 10:00 PM
space-junk's Avatar
Cranking T-bars
okay, i have searched, but i cant find the help i need...
i need to crank my torsion bars about a half inch because im rubbing on my lower valence with the new tires...
now, every thread related to tbars talks about them, but i work better with visuals...
so, anyone have kind of a picture book/walkthru of cranking the tbars? hoping to get this done before the alignment tomorrow...
Old Oct 30, 2008 | 10:05 PM
olharleyman's Avatar
just pull the valance problem solved
Old Oct 30, 2008 | 10:08 PM
Squeebs's Avatar
just have them do it while they align it.... it shouldnt cost extra.
Old Oct 30, 2008 | 10:11 PM
bruzer's Avatar
X2 haha!! Or just get out the saw zaw.
Old Oct 30, 2008 | 11:18 PM
algranger's Avatar
yeah, cut or bend it.. i donno if you want lift just to have lift, then crank them a bit. i dont have pics but its very easy if you just use logic. follow the bars back to where they mount above the frame rail and just turn those bolts- right=higher left=lower, just make sure you cound the turns!
Old Oct 30, 2008 | 11:25 PM
abecedarian's Avatar
Originally Posted by algranger
... just turn those bolts- right=higher left=lower, just make sure you cound the turns!
sure about that?
Old Oct 30, 2008 | 11:32 PM
algranger's Avatar
why? its been a while but thats how i remember it
Old Oct 30, 2008 | 11:36 PM
just checking.
Old Oct 30, 2008 | 11:57 PM
algranger's Avatar
been 2 years almost but i researched and my memory hasnt failed me right=up left=down
Old Oct 31, 2008 | 12:04 AM
and don't forget the nut on the back side.
Old Oct 31, 2008 | 05:03 AM
4runnerx3's Avatar
http://www.off-road.com/trucks4x4/ar....jsp?id=398514
Old Oct 31, 2008 | 05:45 AM
4runnerguy's Avatar
just do what i did and jay351
Old Oct 31, 2008 | 10:20 AM
trbizwiz's Avatar
I think you will need 22 mm socket and 22 mm box end wrench, 7/8's works well too. the socket goes on the bolt end and the box end goes on the nut on top. Lube the hell out of that bolt several times before you mess with it. When i was trying to take my T bars off for some front end work, I ended up twisting both heads off. New bolts are only $7 at the stealership. and the nuts are about the same, but youwill likely have to order them and be out of service for a few days. If youdo decide to do the T bar crank not only should you count the rotations, but you should measure from the top of the hub to the bottom of the wheel well on both sides before and after. the second time the measurement should be a half inch longer and both sides should match both times.
Or have the alignment guy do it. And remember every crank on the T bar takes away from ride quality. this would be a better option http://www.4crawler.com/4x4/ForSale/...ntSpacer.shtml, TRD parts4u has them too.
Old Oct 31, 2008 | 02:05 PM
space-junk's Avatar
well, the stealership cranked it 1/2 inch for free before they aligned it...
still rubs... so i guess imma have to cut the valence... i like the look of it, i really do, so i wont get rid of it...
so, when i cut it, for those of you guys who have done it, what would be the best way to do it??
Old Oct 31, 2008 | 02:43 PM
algranger's Avatar
sawzall or jigsaw
Old Oct 31, 2008 | 02:50 PM
904_runner's Avatar
oxy-torch!!!!
hahaha.
Old Oct 31, 2008 | 02:53 PM
algranger's Avatar
haha maybe an artsy cut?
Old Oct 31, 2008 | 02:56 PM
Whizz wheel you get better control then a sawzall
Old Oct 31, 2008 | 02:58 PM
space-junk's Avatar
hmm... maybe flames??? lol...
Old Nov 1, 2008 | 12:12 PM
algranger's Avatar
Ive found you have the best control with a jigsaw cause its variable speed and such a small blade.
But what is a Whizz wheel?
