Problems with Tach (SR5 cluster)
Old Oct 29, 2008 | 01:34 PM
Jay351's Avatar
So, yesterday while making a parts run for a buddy, while at a red light, I noticed my Tach was sitting on 0.. Truck was clearly running, idling at approx 8-900rpm at the time.
For a few seconds after I left the light, the tach read close but a little off, it would return to 0 at idle (coasting with clutch in, or stopped) then it would return to 200, then 500 then after a few seconds it returned to normal.
I figured whatever, the cluster had a brain fart or somthing () but this morning it did the same damn thing..
So, everything else reads normal, this problem never lasts more then 30 seconds to a minute. I have NO clue whats going on, perhaps the wires going from the coil to the cluster are bad or going bad?
Any ideas?
Old Oct 29, 2008 | 01:37 PM
dirtyXplorer's Avatar
Hey, I have been haveing this same problem. My tach will randomly spaz out while I am idling.
I started a thread a while back and nobody knew what was up. I know there is a wire from the ignitor to the tach and I have been to busy to check it out for shorts/breaks.
Let me know what you figure out.
Edit: here https://www.yotatech.com/forums/f116...e-help-131011/
Old Oct 29, 2008 | 01:47 PM
Jay351's Avatar
Cool! Thanks for the link
I checked this out in the FSM, thank goodness its online for free!
http://personal.utulsa.edu/~nathan-b.../6combinat.pdf
I will clean the Igniter/body and body to battery grounds and go from there. If its still happening I will test the wire.
Ugh, if this wire is bad im gonna start breaking things. I already have to replace a wire going from the ECM to the TPS
Old Oct 29, 2008 | 02:06 PM
yea, if I ever get some free time I was going to try to run a wire from the Ignitor to the tach to test it out. I need to try cleaning the contacts on the plugs and the ignitor's ground too...I hate electrical issues
Old Oct 29, 2008 | 02:17 PM
Jay351's Avatar
yeah, they are the worst!
Old Oct 29, 2008 | 04:39 PM
94yota05gto's Avatar
im having the same problem, its kinda frustrating
Old Oct 31, 2008 | 10:38 AM
Jay351's Avatar
I have not been able to check anything yet, but the problem was much worse yesterday. Tach sat at zero (when idling) everytime I stopped or let the rpms come down. Then about 30 mins later it was working again.
It seems when the tach does act up, it will read rpms (when above idle) but not that accuratly.
I will try the grounds today, its raining so im not too excited to go play outside..
*edit*
okay, so I though I knew where it was but apperantly not. Where is the ground for the igniter?
Old Oct 31, 2008 | 02:49 PM
I am pretty sure its grounded by the bracket holding it to the fender...does anybody know for sure? You could always try taking it off, cleaning the mounts and bolting it back on...
Old Oct 31, 2008 | 04:27 PM
Jay351's Avatar
Well, I thought that might be it, so I pulled it off, cleaned it all off with alchohol (aswell as the bolt used) then I pulled off the battery/body ground and sanded it down, cleaned with alcohol.
I drove up to canadian tire and bought a torque wrench, tach is working great
The grounds were very dirty!
Old Jul 21, 2012 | 11:08 PM
nickxrunner's Avatar
Thanks Jay, for post a link to FSM.
the1998sr5
15
Jul 14, 2020 08:35 PM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
gary4runner
Sep 24, 2015 12:53 AM
Alex Bessinger
Aug 31, 2015 09:17 AM
shisha1999
Jul 13, 2015 11:09 PM
