motor acting up
Old Oct 23, 2008 | 04:55 PM
baseballchamp157's Avatar
motor acting up
ok well I just rebuilt the top end of my motor. I noticed when my truck is running(which is very crappy) that my efi is XTREMELY FREEZING. what in the world would make it cold? And i mean cold. It is also running rich. any ideas?
Old Oct 23, 2008 | 05:25 PM
abecedarian's Avatar
care to take pics and post them....?
what parts of the EFI are freezing?
EFI parts go across the whole engine and into the cab.
Old Oct 23, 2008 | 05:28 PM
its the efi module. the biggest efi part and stand out the most. It connects to the intake manifold.
Old Oct 23, 2008 | 05:30 PM
so, it seems we will need a picture or this makes no sense.
the biggest EFI part is inside the cab of the truck.
hint: either be more descriptive or post a pic.
Old Oct 23, 2008 | 05:48 PM
ok, ill have to get a pick tomorrow or something but it hooks to the intake manifold and your breather that goes to the the filter. its right on the top of the motor. on the top of it it says EFI
Old Oct 23, 2008 | 05:50 PM
Marc's Avatar
I'm guessing it's the intake manifold.
Anyone else want to guess?
Old Oct 23, 2008 | 05:56 PM
<a href="http://s40.photobucket.com/albums/e242/baseballchamp157/?action=view&current=Presentation1.jpg" target="_blank"><img src="http://i40.photobucket.com/albums/e242/baseballchamp157/Presentation1.jpg" border="0" alt="Photobucket"></a>
Old Oct 23, 2008 | 05:57 PM
Old Oct 23, 2008 | 06:00 PM
Originally Posted by baseballchamp157
this it? it get's cold?
Old Oct 24, 2008 | 09:37 AM
yea it gets FREEZING! any ideas
Old Oct 24, 2008 | 09:39 AM
just a 22re's Avatar
if its getting cold then you must have a cro2 set-up and not know it or theres something else going nuts but mine gets hot like everyone elses lol
Old Oct 24, 2008 | 10:13 AM
TOYOTA 1's Avatar
wierd.... you got propane injection on that bad boy?
Old Oct 24, 2008 | 11:20 AM
no its just a regular 22re. the picture isnt mine. I just found it on the internet. it has never gotten cold before. Its always been hot too. So thats why i know somethings wrong. That probably why its running crappy
Old Oct 24, 2008 | 12:10 PM
Cwaters1184's Avatar
weird. you run a freon line into the IM? lol
Old Oct 24, 2008 | 05:23 PM
no, like i said its ALL STOCK! just dont make sence.
Old Oct 24, 2008 | 08:27 PM
desert-rat660's Avatar
if its cold outside the intake can get cold, thats why they run coolant hoses to the throttle body to prevent icing at the throttle plate. what are the temps outside?
Old Oct 25, 2008 | 06:54 AM
I live in florida. the coldest it gets outside is 70 at lowest..lol
Old Oct 25, 2008 | 07:36 AM
it doesn't make sense why it'd be cold. even the thermostat is mounted to the lower intake manifold, so hot coolant from the engine should be warming the manifold up somewhat.
does the radiator get hot when the engine's running?
what type / manufacturer intake manifold gasket(s) did you use?
... or maybe the cold start injector is stuck operating, and the air moving through the manifold is evaporating the fuel, cooling the manifold down. so, have you tried disconnecting the cold start injector plug on the manifold? (if you look at the pic you posted, the top point of the arrow is on the injector)
Old Oct 25, 2008 | 08:01 AM
I used the expensive gaskets from advanced discount auto. The cold start injector plug, does it have a plug on it? or is it the copper line with gas that hooks to the manifold?
is it possible to hook something wrong from the a/c to the manifold?
