Brake Calipers
Old Oct 28, 2008 | 09:52 AM
g_mau18's Avatar
Brake Calipers
Hi I just replaced my brake pads and one of the pistons on my calipers wouldnt compress, my friend said i need a new one. Should I get one caliper to replace just that one or buy two? oh yeah almost forgot...what are some bad *** performance calipers?
Old Oct 28, 2008 | 10:04 AM
waskillywabbit's Avatar
Perhaps service the calipers with a rebuild kit and some emory cloth inside the cylinders.
Stock calipers are more than adequate.
Old Oct 28, 2008 | 10:17 AM
GSGALLANT's Avatar
x2. Rebuild your current caliper. It's quite easy, and the rebuild kit comes with everything you need, except for possibly one piston (if the one that is stuck is pitted from corrosion.)
Old Oct 28, 2008 | 11:16 AM
g_mau18's Avatar
whats emory cloth and why put it inside the cylinder? Thanks for your replys, saved me 100 some bucks
Old Oct 28, 2008 | 11:35 AM
Try "emory cloth"
Vita sine litteris mors est.
Old Oct 28, 2008 | 11:38 AM
Matt16's Avatar
It's like sand paper. You basically are sanding down the rust that build up behind the pistons.
If they are just sort of sticking, just work them back and forth until they move freely, then bleed the brakes to get all the crud out of the wheel cylinders (inside the calipers). Its a judgment call, you may end up with too much rust in the brake fluid which could then go on to clog up other parts of the brake system. It did work for me though.
Old Oct 28, 2008 | 11:55 AM
RobD's Avatar
You wouldn't happen to have a part number for or sell said rebuild kit, now would you?
And I just reached the 1000 post milestone. Woohoo!
Old Oct 28, 2008 | 12:01 PM
IIRC rebuild kit was about $35/side at the local auto parts store. I stripped the calipers, blasted, powder coated, completely rebuilt and had brand new calipers in essence for under $100.
Jcrawl94
10
Oct 24, 2015 04:34 PM
Sep 4, 2015 09:27 AM
ojm3
Aug 28, 2015 12:26 PM
bfmcelroy
Aug 18, 2015 06:42 AM
ty1er
Aug 1, 2015 11:53 PM
