Brakes locked up - what to check?
Old Oct 28, 2008 | 07:53 PM
gwat's Avatar
Put a whole new brake system on my truck - master cylinder, calipers, wheel cylinders, lines, drums, rotors.
Took it for a drive and the brakes pump up to the point where they eventually pretty much are locked up. 1st gear strains to get the truck rolling after a few minutes of driving and braking.
What should I check first? I'm going to start with a bleed. Could it be a faulty master cylinder? Contamination in the lines blocking things up? Thoughts?
Old Oct 28, 2008 | 08:00 PM
OSU4Runner's Avatar
Please tell me you did bleed them after you finished the install right? Did you bench bleed the master cylinder?
Old Oct 28, 2008 | 08:02 PM
abecedarian's Avatar
see if you can narrow it down to only one wheel. if you can't, i.e. all 4 are locking, or say both front or both rear, I'd be checking the mc.
if you get it down to one wheel, check there.
Old Oct 28, 2008 | 08:03 PM
desert-rat660's Avatar
make sure u didnt overfill the master cylinder, also check the brke pedal height make sure the rod that hooks to the pedal assembly isnt adjusted to the point its not releasing the brakes, it should have some free play. are all 4 wheels locking up?
Old Nov 7, 2008 | 07:01 AM
gwat's Avatar
aha. I narrowed it to the front two wheels locking up. Realized that the pushrod needed to be adjusted and everything works great now. Thanks everyone!
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
Eggslinger
Jun 8, 2019 03:32 PM
jasonty
41
Dec 23, 2018 01:00 PM
Johntom240
7
Jul 13, 2015 12:18 AM
