Baffled...
Old Oct 24, 2008 | 03:30 PM
Matt16's Avatar
Question Baffled...
My engine doesn't have an oil baffle in between the sump and the block. What's with? I'm guessing it didn't just fall off. Did some 22REs come with no oil baffle?
Mine:
Another:
Old Oct 24, 2008 | 03:34 PM
toyospearo's Avatar
um...that doesn't look right.
Old Oct 24, 2008 | 03:54 PM
Matt16's Avatar
??? It has been noted that the baffle is missing in the 1st picture. I'm not sure what you are getting at exactly.
Old Oct 24, 2008 | 03:57 PM
fillsrunner4's Avatar
the baffle on the 22re should be in the oil pan
Old Oct 24, 2008 | 03:58 PM
just a 22re's Avatar
thats where mine is pain in the butt to get that pan off too
Old Oct 24, 2008 | 04:11 PM
Like this
Old Oct 24, 2008 | 04:23 PM
that it is phill lol
Old Oct 24, 2008 | 04:26 PM
Matt16's Avatar
It ain't. I had the front diff out a while ago, so I dropped the pan and cleaned out the timing chain pieces, guides and a bolt. There definately wasn't any baffle in the pan.
Old Oct 24, 2008 | 04:28 PM
If its not in the pan I bet you could find one to put in online somewere. I found some on ebay and a few other site with a quick search. I wondered the same thing the other day working on a 22re and found that it was in the pan.
did someone like the po remove it and play a joke on you did they put a bolt in there so you go what the hell is this?? is there a note on the bottom of it? lol
Old Oct 24, 2008 | 04:29 PM
toyospearo's Avatar
My mistake. I missed that .
sorry
Old Oct 24, 2008 | 04:39 PM
TOYOTA 1's Avatar
that 2nd pic is not a pic of a 22re!
Ive never seen a baffle like that on one either.
like said above there is a Lil cheesy baffle in the pan but thats it!
Old Oct 24, 2008 | 07:31 PM
Matt16's Avatar
Probably a 3VZE then. THe point is that my 22RE doesn't have one I can't think its going to cause trouble- I don't spend much time accelerating fast or braking suddenly. Maybe someday I'll get around to dealing with it.
Old Oct 25, 2008 | 12:40 AM
space-junk's Avatar
replace it and forget it...
might be fun to get some high temp laminate paper and leave yourself a laminated note in the bottom of the pan reminding yourself to buy one then next time you have to take the pan off...
Old Oct 25, 2008 | 02:04 AM
anotherjeff's Avatar
matt, im thinking that the 2WD has a non-baffled pan...
Old Oct 25, 2008 | 06:33 AM
abecedarian's Avatar
2wd has a baffle / windage tray in the oil pan.
Buggy
Apr 21, 2015 04:15 PM
ryan954
7
Jan 26, 2012 06:28 PM
