Im seing blue, LED that is
Old Oct 25, 2008 | 06:00 PM
SR5's Avatar
SR5
Talking Im seing blue, LED that is
I got my running lights from japan today
I added a LED, it has 12 projections, or 12 lights
In addition i did i full Interior LED conversion of EVERY LIGHT
cigarette lighter - blue
Ash tray - red
glove box - blue
light the shines on your Ignition switch light - blue
gauges - blue
heater controls - blue
Tearing apart the dash for the first time
cluster in my lap
Old Oct 25, 2008 | 06:22 PM
woodendude's Avatar
Wow, looks good! I've got to do that one day, the only thing that lights up on my cluster are the trouble lights and I didn't even know the heater controls light up (91 4runner) and my glove box and ashtray are also in the dark. How difficult was pulling the dash?
Derek
Old Oct 25, 2008 | 06:24 PM
iamsuperbleeder's Avatar
holy crap man, nice work!
What kind of LEDs did you use in the dash and where did you get them? I have some green one's in mine that I got off eBay, but their horrible; I can harldy see my gauges at night...
and I don't think there's a glove-box like on the standard models... must be an SR5 thing or something, I dunno; I've torn my dash apart many times, I just figure I would have seen that by now...
Old Oct 25, 2008 | 06:46 PM
4banginRunner's Avatar
very nice!!
where did u get the blue LED's from?
thats exactly what I'm looking to do with mine
Old Oct 25, 2008 | 07:17 PM
stagger_lee's Avatar
Originally Posted by SR5
I have nightmares about this. This is about the only thing I will not touch on mine or any truck for that matter. I would rather rebuild a tranny! You got balls. Looks killer!
Old Oct 25, 2008 | 09:32 PM
RobD's Avatar
Actually, pulling the dash isn't that hard, nor that time consuming. I suppose I'm down to under half an hour to pull it and reinstall it.
Old Oct 25, 2008 | 09:47 PM
Mic09dcsm's Avatar
A tranny, you're crazy.
Old Oct 25, 2008 | 10:13 PM
SR5's Avatar
SR5
super super easy,
here is the write up https://www.yotatech.com/~corey/tech...lo/l33t35t.htm
http://www.superbrightleds.com/mini-wedge.html
highly recommend this site, their bulbs are great, NO SPOTTING
Old Oct 25, 2008 | 10:47 PM
algranger's Avatar
wow very nice
Old Oct 25, 2008 | 11:23 PM
94toyotapickup's Avatar
loving the blue tac and speedometer but , one thing i didnt like but id get over it was no redline, i like to see it even tho i know when to shift without lookin at it.
Old Oct 26, 2008 | 04:36 AM
hazza0224's Avatar
ok i got a question and a answer for some of yous.
first of you can get alot of Light emitting diodes (LED) of ebay
i do electronics servicing and im wondering if you solder on this job or are you using wedge bulbs?
my mate said there are these small condom like things that are colored e.g blue and they go over your current bulbs. they wouldn't be as blueish an LED but still thats an easer way
Old Oct 26, 2008 | 05:56 AM
sixt5's Avatar
but if your already at the bulb why not just switch em?
Old Oct 26, 2008 | 06:32 AM
RobD's Avatar
The LEDs he is using are actually 5 LEDs in a common housing with the proper 194 two prong base. The have 4 LEDs that illuminate radially and one in the center firing forward.
http://www.superbrightleds.com/specs/bulb_specs.htm#x5
Look at the WLED-5x and you'll see what I mean.
Old Oct 26, 2008 | 06:43 AM
awareness's Avatar
They also have LED's in different configurations with more than just 5 bulbs as well. Any reason why you can't use those? Are there any size constraints in the install?
Old Oct 26, 2008 | 08:43 AM
so which 194 replacement bulbs off of this site did you use in your dash gauge cluster?
Old Oct 26, 2008 | 08:47 AM
Belize Off Road Team's Avatar
Those corners are from a Mk III or IV Hilux? did you get the indicators to work? or are they just corner lights? Cause i might go that way if you got the indicators to work.
Old Oct 26, 2008 | 08:48 AM
Originally Posted by Belize Off Road Team
Those corners are from a Mark II or III Hilux? did you get the indicators to work? or are they just corner lights? Cause i might go that way if you got the indicators to work.
you can make anything work with a little wiring
Old Oct 26, 2008 | 08:52 AM
True but the Hilux came factory with the indicators in the corner lights.
Old Oct 26, 2008 | 09:04 AM
well right, but I thought most trucks are wired with just the single plug going to the corner lense with just 2 wires going to it... therefore, you would have to run your own wires
at least I know that's how mine's set up; if I wanted to put signals in my corners, I'd have to run some wire; well, maybe just one wire for the blinker hot and just use a common ground...
Old Oct 26, 2008 | 10:33 AM
Or the fact that if you could just take the bumper indicator wires and wire them into the bumper so you can hook up to the corner lamps.
