Im seing blue, LED that is
Old Oct 26, 2008 | 11:05 AM
SR5's Avatar
SR5
Originally Posted by hazza0224
ok i got a question and a answer for some of yous.
first of you can get alot of Light emitting diodes (LED) of ebay
i do electronics servicing and im wondering if you solder on this job or are you using wedge bulbs?
my mate said there are these small condom like things that are colored e.g blue and they go over your current bulbs. they wouldn't be as blueish an LED but still thats an easer way
NOOO DONT NOT USE THE CONDOM CAPS they suck, these are all wedge LED bulbs, and they work great
Old Oct 26, 2008 | 11:11 AM
SR5's Avatar
SR5
Originally Posted by iamsuperbleeder
so which 194 replacement bulbs off of this site did you use in your dash gauge cluster?
use the CONE style, they leave no spotting, if you use the higher ones with 2/4/6 LEDS in one bulb they will SPOT
3 of these
2 of these
Old Oct 26, 2008 | 11:12 AM
SR5's Avatar
SR5
Originally Posted by Belize Off Road Team
Those corners are from a Mk III or IV Hilux? did you get the indicators to work? or are they just corner lights? Cause i might go that way if you got the indicators to work.
yes they work, i wired them together, i got them from cbrsport17 $35 shipped to my door,
he can get you a pair, just PM him
edit: Just a note cbrsport17 is no longer based in Okinawa and is currently not able to source JDM parts.
Old Oct 26, 2008 | 11:13 AM
iamsuperbleeder's Avatar
ah ok, see I used ones that just have one big LED on them... their horrible... I have amber cone type ones in my corners, so I'll have to look into that, thanks!
Old Oct 26, 2008 | 02:47 PM
  #25
RobD's Avatar
I used the WLED-5x LEDs on mine.
Old Oct 26, 2008 | 02:55 PM
  #26
cbrsport17's Avatar
Damn, your truck looks good!!! I am glad i could help out...unfortunately i just got rid of my Surf....it was a sad sad day, but at least i can still scour the junkyards for the people here on Yotatech!!!! Your dash looks way better than mine did, but i only had forward facing leds in there, next time i know to buy those wleds from that website!!!!
Old Oct 26, 2008 | 04:16 PM
  #27
SR5's Avatar
SR5
thanx man i l0ove it to
also everything worked out great with the lights
i can vouch for cbrsport12, so if guys need anything from japan, hit him up
Old Oct 26, 2008 | 04:35 PM
  #28
stagger_lee's Avatar
I coming back to look at your lights! Very cool.
Originally Posted by Mic09dcsm
A tranny, you're crazy.
I hate electrical anything. My brain doesn't grasp the concept.
Old Oct 26, 2008 | 04:49 PM
  #29
Jay351's Avatar
Nice! I too used the 5led wedge bulbs in my cluster/dash led changeover. Love the lack of spots! Is yours very blue? I notice that mine has a very slight hint of green in there, im assuming the film on the faceplate.
You get the two #194's in your turn signals too?
Old Oct 26, 2008 | 05:55 PM
  #30
SR5's Avatar
SR5
i haven't noticed the green yet, but im sure i will
and ya i got amber LED for the turn signals
Old Oct 26, 2008 | 05:56 PM
  #31
SR5's Avatar
SR5
ya i was like that to, but somehow i just did little stuff here and their and once i got to doing the dash and lights, it was easy
Old Oct 26, 2008 | 07:27 PM
  #32
Jay351's Avatar
The electrical connections are no problem. They are all different and only attach one way The only bad thing is after taking my dash off so many times, it squeaks now
Old Oct 26, 2008 | 07:38 PM
  #33
aviator's Avatar
well right, but I thought most trucks are wired with just the single plug going to the corner lense with just 2 wires going to it... therefore, you would have to run your own wires
at least I know that's how mine's set up; if I wanted to put signals in my corners, I'd have to run some wire; well, maybe just one wire for the blinker hot and just use a common ground...
North American trucks came wired for running light only in corner lens, Japan and most other markets came wired for turn signal repeaters in corner also.
The glove box, ashtray and ignition key lights were part of the optional convenience light package. They can be added relatively easily with wreck yard parts but to make them work like a factory install is a wiring headache I'm still working on... the ignition light is on a time delay that needs a full factory harness to make functional, other then that it is a simple splice and play job.
Old Oct 26, 2008 | 07:40 PM
  #34
thedude42's Avatar
Originally Posted by 94toyotapickup
loving the blue tac and speedometer but , one thing i didnt like but id get over it was no redline, i like to see it even tho i know when to shift without lookin at it.
you can see it... its just a dark blue line now
Love the look cant wait to change my bulbs
Old Oct 26, 2008 | 08:42 PM
  #35
wardriver's Avatar
Tempting...these gauge lights are not dim-able though are they?
Old Oct 26, 2008 | 09:19 PM
  #36
RobD's Avatar
Yes, the LEDs from Superbright are, indeed, dimmable with the dimmer switch.
Old Oct 26, 2008 | 09:23 PM
  #37
Off-Road Master's Avatar
Very cool. I like the JDM signal lights. How did you source those?
Old Oct 26, 2008 | 09:27 PM
  #38
space-junk's Avatar
read the early posts before asking questions...
CBRSPORT17
btw, cbr, why'd you get rid of the 90?!?!?! that think was freaking sweet!!
Old Oct 26, 2008 | 09:28 PM
  #39
Jay351's Avatar
They sure are!
Old Oct 26, 2008 | 09:54 PM
  #40
cbrsport17's Avatar
CBRSPORT17
Wife wants to bring a van to Turkey instead of the Surf...Since i ride a motorcycle to and from work, she figured that the car needs to be something she liked drive and she didnt really like driving the surf. The van will be good for when family comes and visits tho...i will just have to try and find another good Toyota for a project later on down the road....
