Top dash
Old Oct 27, 2008 | 08:50 AM
Gokumono's Avatar
Top dash
using the picture that SR5 posted.
Does anyone know how to take that top dash area off?
Mine is cracked, and 1 or 2 other times when i took apart that whole front area i was wanting to get it off for various reasons but couldnt just take it off.
Old Oct 27, 2008 | 08:53 AM
scuba's Avatar
This is where i would start....
Old Oct 27, 2008 | 08:56 AM
Gokumono's Avatar
I think i did take those off......... and it still didnt work. Been a little while since i did try to get it off. I think there was something else holding it though.
Old Oct 27, 2008 | 09:03 AM
scuba's Avatar
maybe those tabs in the back, well technically the front, you know what kind of tabs im talking about im sure...I mean, i would just investigate to my fullest extent, pull as hard as possible and see where its held up, and see whats holding it there. If that doesnt work BFH time
good luck
Old Oct 27, 2008 | 09:44 AM
Gokumono's Avatar
BFH time?
Dont have a new dash to replace it if i do just rip it out.... lol.
Old Oct 27, 2008 | 01:27 PM
scuba's Avatar
Big Freakin Hammer
Old Oct 27, 2008 | 01:47 PM
Belize Off Road Team's Avatar
OR just go to tech write-ups and look for indiglo gauges. it shows and tells you how to take off the dash
Old Oct 27, 2008 | 02:14 PM
aviator's Avatar
That leading edge is screwed in from behind to the main dash trim part. if you look way at the bottom of the cowl roughly above the steering coloumn there is a phillips screw or two down there as well and I think one above the glove box area. Once you get them all out you need to heave up and back firmly to "pop" the dash out of the plastic clips at the base of the window.
ps you'll know you have all the screws out when you can sort of lift and wiggle the dash up and down freely... then is the time to tug it out.
when you want to put it back in you need to make sure all the black plastic clips are in the dash part not the window frame base... some times they come out of the dash and it is easier to put back if the clip pins are in the dash part.
Old Oct 27, 2008 | 06:54 PM
Gokumono's Avatar
Thanks. Should be able to hopefully figure it out now.....
I think i got to that point once. Had it wiggling a little bit, but seemed like it wouldnt come out and didnt want to just yank on it and break something....
ashersullivan88yota
Jan 18, 2022 05:37 PM
jasonty
41
Dec 23, 2018 01:00 PM
mussy01
Dec 13, 2016 08:20 PM
ViperTT
Aug 14, 2015 05:27 AM
TDonkey
Jul 26, 2015 10:14 AM
