91 toyota ex cab brake problem
Old Oct 17, 2008 | 04:58 PM
lippy's Avatar
Well i put new brakes all the way around and they start draggin replaced the caliper and it is still dragging and brakes get hot it is the passenger front and they do have new rotors and drums.I am getting fustrated at it it is my only means of transportation to and from work.
Please any help would be i would be thankful.
Old Oct 19, 2008 | 07:34 AM
lippy's Avatar
No one has a clue please help.
Thanks
Old Oct 19, 2008 | 10:30 PM
breknraj's Avatar
How did you go about adjusting everything after the replacements, and are you certain that you recieved the proper parts to start with?
Old Oct 19, 2008 | 11:29 PM
abecedarian's Avatar
how do you know it's dragging?
just 'cause it's getting hot?
maybe it's the only one working?
Old Oct 21, 2008 | 07:42 PM
desert-rat660's Avatar
check the fluid level in the resevoir if its over filled it can cause the brakes to drag
Old Oct 21, 2008 | 08:47 PM
Originally Posted by lippy
>snip<
Thanks
People have clues, but you have to answer their questions.
So, do you have a clue?
Old Oct 22, 2008 | 01:29 PM
iamsuperbleeder's Avatar
lol
sometimes the rubber brake hoses can get old and colapse when letting off the brake and keep enough pressure to the caliper to make them drag; just a thought...
Old Oct 27, 2008 | 07:04 PM
lippy's Avatar
Thanks guys,
i know it is dragging because i can set on a hill and push in the clutch and it wont roll.But it does not do it all the time.Only some and iam still struggling with this issue.It is the fronts because they are the ones that smell like heck.I can drive to work and they will be fine then on my way home half way they start.I am stumped it seems they would do it all the time.
Thanks everyone.
Old Oct 27, 2008 | 07:08 PM
so you replaced the caliper(S? both calipers?)
did you grease the slides?
did you check them for wear?
sure the rear brakes aren't hanging up, but not working right?
Old Oct 27, 2008 | 07:22 PM
could be the master cylinder too
6th Gear
19
Dec 10, 2019 07:31 AM
gillesdetrail
Nov 19, 2019 12:56 PM
Aleeex_u
Jun 5, 2016 06:52 PM
PureTacoma_Tundra
PureTacoma_Tundra
Jun 29, 2015 09:45 AM
94more
Jun 19, 2015 01:55 PM
