Removed head, pistons looking bad
Old Oct 27, 2008 | 06:17 PM
t0mwat3r's Avatar
Well due to a failing head gasket my 4runner was leaking coolant out the side of the block, anywho tore down the motor with the help of my girl friend and this is what it looked like
and corrosion where the coolant was leaking...
Old Oct 27, 2008 | 06:20 PM
abecedarian's Avatar
aww... c'mon. thought you'd have pics of the girlfriend turning wrenches and stuff.
just kidding....
anyhow.... that's just wierd. you can still see the crosshatch pattern in #3 (last pic).
don't worry. I'll be rebuilding an engine right beside you.
Old Oct 27, 2008 | 06:24 PM
Matt16's Avatar
Can't really tell, but it looks like carbon build up to me. Not something to worry about if it is that. Just pour some solvent (I heard brake fluid works well) on there and let it sit. Should remove it.
None of my girlfriends ever knew what a socket wrench was.
Old Oct 27, 2008 | 06:28 PM
wonder where the build up came from?
look at the intake runners (looks like #2 and #3) in the pic below.
brake fluid might clean up the carbon problem on the pistons (not likely, but okay), but not the oil in the intake.
Originally Posted by t0mwat3r
Old Oct 27, 2008 | 06:39 PM
t0mwat3r's Avatar
i dont know what it is but its even in the upper intake and throttle body, any ideas?
iamsuperbleeder's Avatar
looking at that, I bet you'd find worse looking crap on the inside of the upper intake manifold, and on the back of the butterfly valve on the throttle body...
go ahead, take a look, I bet you'll find the good ol nice black goo crap; I can tell it's hit you too form the one pics and being able to see inside the lower intake manifold a little bit
EDIT, ha, I was right... you post too quick man...
https://www.yotatech.com/forums/f116...thread-142091/
Old Oct 27, 2008 | 06:42 PM
plain and simple, it's caused by the PCV system.
Old Oct 27, 2008 | 06:45 PM
darned PVC
Old Oct 27, 2008 | 06:58 PM
Matt16's Avatar
You could add a little collector, that way there wouldn't be so much gunk in the intake:
Old Oct 27, 2008 | 07:00 PM
how about a pic of that on a 22re?
Old Oct 27, 2008 | 07:01 PM
Originally Posted by iamsuperbleeder
darned PVC
darned dyslexic keyboards.
Old Oct 27, 2008 | 07:02 PM
I've been wanting to add one of those, but I'd just assume change the PCV valve every other oil change rather then empty out collected oil every couple of weeks
Old Oct 27, 2008 | 07:03 PM
i Kno, it tis agrrivatingg, is not it...
Old Oct 27, 2008 | 07:04 PM
the proper ones drain the oil back into the valve cover.
Old Oct 27, 2008 | 07:05 PM
I've never seen a proper one then... hmmm...
Old Oct 27, 2008 | 07:12 PM
cause they don't exist.
Old Oct 27, 2008 | 07:13 PM
well now that would explain why I've never seen one
if they were serious about it, they'd use centrifugal force to cause the oil to collect on the outer side of the chamber, then drain the collected oil down into the crankcase, not the valve cover.
a simple separator like in the pic above wouldn't do anything to the aerosolized oil
Old Oct 27, 2008 | 07:15 PM
kinda like those pre-filters you can put atop snokels?
Old Oct 27, 2008 | 07:22 PM
STEvil's Avatar
I think the intent is to re-burn the oil to it acts like some of that top-end conditioner that "Lucas Oil" sells.. kind of seals the valves and rings a tad if you're running it hard enough to blow out through the PCV system.
Either way I dont like it either.
