Removed head, pistons looking bad
Old Oct 27, 2008 | 09:10 PM
Matt16's Avatar
Originally Posted by abecedarian
if they were serious about it, they'd use centrifugal force to cause the oil to collect on the outer side of the chamber, then drain the collected oil down into the crankcase, not the valve cover.
a simple separator like in the pic above wouldn't do anything to the aerosolized oil
I thought they condensed the aerosolized oil by bubbling the oil vapours through the puddle of oil there.
Old Oct 27, 2008 | 09:23 PM
abecedarian's Avatar
look again.
Old Oct 27, 2008 | 11:21 PM
Matt16's Avatar
look again.
It looks to me like there is a clear tube running down the edge of that sticker to the oil pool, its hard to tell, but it would make sense, otherwise the separator would serve little purpose as you pointed out earlier.
Old Oct 28, 2008 | 08:16 PM
desert-rat660's Avatar
pcv just another emmision control device, damn californians and there smog problem =)
Old Oct 28, 2008 | 10:25 PM
  #25
drew303's Avatar
oil can enter through the front vent on the valve cover as well. Still a vacum
Old Oct 29, 2008 | 12:09 AM
  #26
sh0kk86's Avatar
mine looked the same when i took my head off on my 86 22r.
i cleaned it all off with brake cleaner, and carb cleaner for the intake /carb.
i took off my egr system, and the hole is was a pinholes compared to what it is without the carbon.oily buildup.
i think its because of my aap causing my truck to run really rich a while back.
Old Oct 29, 2008 | 03:26 AM
  #27
misterzee's Avatar
All the gunk doesnt become an issue until your engine becomes worn past a certain point... they designed it to work properly while the system is in its prime... you start seeing the gunk after about 75k to 100k miles usually... the deposits on your piston crowns is not going to hurt anything...
bigjstang
Jun 2, 2025 03:56 PM
icentropy
Sep 16, 2020 02:47 PM
jasonty
41
Dec 23, 2018 01:00 PM
Sep 4, 2015 09:27 AM
thefishguy77
Jul 30, 2015 10:59 AM
