PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 [12] 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. Oem Plastic timing chain guides?
  2. OME rear leaf spring forward bushings - sleeve?
  3. 92 4x4 truck 3.0 cel codes 12, 14
  4. Automatic 1987 pick up issues
  5. 22RE head gasket repair price?
  6. Intermittent runs great/runs poorly/stalls/won't start
  7. 87 4runner rear window issue
  8. 1991 Pickup 3vze runs rough at operating temp check engine light on no codes
  9. Steering feels way worse after replacing suspension parts
  10. 22R Timing / Vacuum Advance Help
  11. 3.0 VZE valve adjustment / valve cover FIPG
  12. Replaced MAF and now Engine wont start
  13. I’m looking for a shifter bezel and rear seat latches for a 1st Gen 4Runner
  14. 1991 Truck Build
  15. Swapping 22re from 2wd truck into 4wd truck?
  16. 1988 22RE No power to fuel pump
  17. 93 3vze Fuel Tank Vent
  18. O2 sensor is larger than the one I removed.
  19. Help with part numbers fuelpump/hanger
  20. Frame cross member
  21. Header
  22. Flat Bed
  23. Brake Line
  24. LCE "3VZ Caliper and Rotor" Upgrade. Is it worth it?
  25. Freewheeling hub: axle only unlocks if turned backwards
  26. sr5 cluster busted?
  27. Messed up idle on 92 22re
  28. Crankshaft mark
  29. Best brand of catalytic converter?
  30. New Toyota reman alternator
  31. 22r Oil leak front of engine
  32. short at door courtesy switch.
  33. difference between 86-88 and 89-95 ifs double cardan joint
  34. 1987 4runner rear window switch
  35. 88 4Runner (3vze) electrical gremlins
  36. Fuel Pump Test
  37. 3VZE Fuel Pressure Regulator question
  38. 1992 Toyota pickup 2wd egr issue
  39. 4runner for parts price
  40. Roof Rack Mod - 2nd Gen
  41. 86 V6 rear differential upgrade.
  42. Insurance Value
  43. 3.0 VZE ignition timing
  44. Tps calibration
  45. 1987 Stolen Pickup Recovered - Help ID'ing parts for repair
  46. Center console armrest
  47. tickticktickticktick 5VZE
  48. 4Runner 3.0 Engine Sensor Question
  49. what is this?
  50. The case of the missing EGR sensor
  51. Seat swap help
  52. Can you?
  53. Fuel tank
  54. Front air shocks 2wd
  55. A/C 4runner to pickup
  56. 1992 Toyota Pickup 22RE turbo conversion and build up
  57. Seats interchangeable?
  58. My third Denso starter went bad within a year
  59. Did the Toyota use clearcoat on white 1988 pickups?
  60. Fuel filler neck needs replacing any tips?
  61. Overheating
  62. AC kit works great but caused problem
  63. 92 4Runner 3.0 Bad clanking sound in bell housing
  64. Can We Get this Stickied please? 90s 22re Pinging solution.
  65. John Muir's Idiot Book for 75-87 Toyota Pickups
  66. Loose Steering 4runner
  67. Not a Yota but 4" lift and 40's???
  68. Cab Swap Info Needed: 1988 Xtra Cab (3VZE w/Auto) on to 1987 Xtra Cab (22R w/manual)
  69. Looking for 2.4 Diesel information
  70. Ethanol-free gas
  71. 89 Toyota Pickup Sitting For 3 Months
  72. Oil leak help! What is the plate called need to get gasket!
  73. heater and ac switch
  74. 3rd gen running problems
  75. Orphan identification (91 22RE)
  76. 1987 22r idle issue?
  77. jennygirl's 88 4runner build thread
  78. 1986 pickup start and die after 3 seconds.
  79. Ac compressor wont disengage
  80. Another 22re cranks, does not fire, fuel injectors not firing??
  81. Ignition key sticking
  82. Torsion bar match mark missing
  83. '95 3vze 4runner parked 1 week won't start now...
  84. Code 52 - 1989 Toyota Pickup 5spd 4x4 3vze
  85. Assess/Repair AC or Just Replace it; Seeking opinion based answers
  86. Alternator issue
  87. Speedometer / trans issue
  88. 88 3.0 Random Hard Starts
  89. 88 3.0 Random Hard Starts
  90. 1986 4runner slow crank
  91. 1986 pickup 4x4-Throw out bearing
  92. 37's on 94 pickup
  93. Brake Caliper Rebuild
  94. 89 yota pickup stall/start issues HELP
  95. 1991 Toyota Pickup Clutch replacement
  96. 22R bad idle and stalling when braking
  97. What the hell should I do?
  98. Evap issues
  99. 22re fuel pump?
  100. 86 Truck Front Bumper Build
  101. buying a used 3vze for a swap - things to look for
  102. Headaches while driving - possible carbon monoxide?
  103. 90 3.0 3VZE Low idle/missing when hot
  104. Oil leak 1992 Toyota p/u.
  105. 22RE turbo thermostat OEM
  106. high steer install in a 86 Toyota Pickup
  107. 15 inch wheel options for 89 2wd p/u
  108. Timing belt part numbers
  109. Really, really bad fuel mileage 95 4runner
  110. 88' 4runner 3VZE Fender Liner Repair
  111. First Gen 4Runner Bumper/Hitch options
  112. 22re bubbles in overflower. New block new head
  113. Replacing outer CV boot while doing front brake overhaul?
  114. Clunkity clunk goes the drive train....
  115. 22re low idle on warm starts help!
  116. cab interchange
  117. 1986 Dlx bench seat upholstery with fold down arm rest
  118. '86 Toyota 22R air injection question
  119. Won’t start when warm
  120. "Stand Alone" harness and/or engine swap adapters
  121. Frame replacment
  122. Rough Ride 93 Pickup
  123. 1991 22RE Fuel Pressure Banjo Bolt
  124. Ford Starter Solenoid Conversion
  125. 1986 Toyota Hilux Turbo 4x4
  126. 4runner transmission problem
  127. TPS/Multimeter Troubles
  128. 1993 3VZ cranks, will not start
  129. '90-22r to 2.7L i4 swap
  130. 86 pickup dash lights
  131. Groaning noise
  132. Looking for a valve adjustment or valve job in Northern CA or Southern OR
  133. 22RE headbolts recommendation: 87 4runner dlx
  134. 1997 Hilux RN85 Climate Control Cable Removal
  135. Ground wires for gauge cluster/interior? 22re 1990
  136. 1986 Toyota Pickup Barn Find
  137. Front Wheel center caps, Nerf Bars or Rock sliders
  138. 3vze tick noise
  139. Need help on my 88 3.0 Toyota pickup
  140. Lower dash knee panel 1990 22re Screws
  141. I just rebuilt my steering box and you can too
  142. TV Cable adjustment related to reverse not working?
  143. 89-92 & 93-95 Grille Interchangeability
  144. Truck died after knock issue
  145. giving up on IFS, low SAS time
  146. 1990 Toyota Pickup 3.0 RV electric cooling fan problems.
  147. 87 22r pickup, fuel issue/stalls/almost stalls when idling, it's an auto trans btw
  148. 1992 4Runner Won't Hold Tranny fluid at all
  149. Timing after Tps adjustment? Dashpot? Code 11? Rich and lean at same time?
  150. replacing head gasket
  151. failure to start after a long haul
  152. Gen 2 4wd swap lost reverse?
  153. Easier to source AC parts (Ac amp, sub harness etc)
  154. 92 pickup, patch panels needed
  155. New throttle cable for 91 doesn't seem to match
  156. 86 22RTE Air intake hose?
  157. 94 4Runner 3.0 head gasket repair
  158. 86 Restoration Video Series (in progress)
  159. Correct Starter relay circuit fix
  160. Differences between 1990 and 1992 3vze
  161. 1994 4runner ac not working after new ac fan control switch
  162. Pinout website idea
  163. Relocating side mirrors
  164. Gasket set and water pipe
  165. Low Temperature gauge mystery
  166. 93 pickup parts ID
  167. Headlight replacement.
  168. 90 4 Runner no crank
  169. Engnbldr street RV head. Needs new valves
  170. Improving door security on my '86 pickup?
  171. lower ball joints
  172. '91 22re 4x4 passanger side cvaxle popped from front diff
  173. Who's bought a California cat converter lately?
  174. White smoke puffs when up shifting
  175. 1987 Toyota Truck Advice
  176. Tailgate troubles
  177. '94 4runner lift kit conundrumcan i use t100 CV with lift kit?
  178. 3 wire connector
  179. Tire size
  180. Erratic Timing w/ new TPS
  181. 93 Toyota pickup no start
  182. Post-4WD Swap issues
  183. Spring shackle source???
  184. Transmission Solenoid identification??
  185. Low temperature gauge 180 Thermostat 22re 1990
  186. Power steering fluid
  187. remove interior fuse box
  188. Help me diagnose engine whine (with videos)
  189. 1986 weber 32/36 4runner struggles to keep up with traffic
  190. 86 22RE Fuel Injection prob got me stumped
  191. My 91 jerks, vibrates, bucks after removing foot off gas pedal, then reapplying gas ?
  192. 1986 Toyota 4Runner Lower Control Arms
  193. Suggestions on rear window parts cheap
  194. 22re air conditioning works at cold start then shuts off when it reaches temperature
  195. Stumped! 22RE engine and cig fuses shorted but not blown.
  196. 94 3VZE lagging acceleration
  197. Electric radiator fan.
  198. timing chain noise at idle
  199. 1990 manual trans with 1994 22RE motor, what is needed
  200. Break line leaking
  201. 1988, 3VZE, CA model, with a/c: vacuum lines
  202. 1988, 3VZE, CA model, with a/c: vacuum lines
  203. No Speedo
  204. 1991 Pickup 3VZE will not start
  205. 95 4-runner front suspension/steering questions
  206. Toyota pick need help badly
  207. None of these connections looks like a Diagnostic Port
  208. 3vze Got spark, Fuel, cranks but no start
  209. 87 1-ton pickup with hard / soft brake pedal
  210. Thoughts on this ‘89?
  211. What could this be?
  212. Fuel Pump Electrical Issue
  213. bad Ecm?
  214. Old man emu lifts for PICK-UP 4WD 1984-94
  215. Stand alone wire in stereo area
  216. Rear Frame Rust Overhaul + Suspension
  217. 1989 22RE pickup A/C
  218. Motor Swap 1985 Pickup Truck with 1990 motor 22RE
  219. 3VZ adjusted timing, now won’t idle
  220. Looking for a parts source
  221. Looking for a a front end rebuild kit. 1990 Toyota Pickup.
  222. toyota 2L valve stem replacement
  223. Low Gas warning
  224. 3.0 VZE, what is this vacuum line?
  225. Forgot to measure how far cranked the torsion bar was...
  226. 100k + first gear oil change
  227. A/C Hoses
  228. Who’s the “go-to” for parts…22re 94 truck
  229. 1986 4runner vibrations at low speed (manual transmission w56)
  230. 86 22re won’t accelerate, HELP!!
  231. FYI. Worm drive clamps for 22re radiator hoses
  232. Oem thermostat housing bolts 22re
  233. Parking break repair
  234. What type of grease for wheel hub and knuckle?
  235. H4 headlamp housing conversion
  236. Tailgate "TOYOTA" decal OEM size?
  237. Need a pic of a mounted cowl
  238. What is this canister?
  239. 1991 Pickup trans drops gift with oil change
  240. Where can I access a Parts Diagram?
  241. 1990 Toyota Pickup CV Axle Replacement sources
  242. Check Engine Light not working on 95 4Runner
  243. Denso or NGK spark plug wires for 3vze Engine
  244. What is this tailgate wire?
  245. 86 Pickup loses power after driving a while
  246. 86 toyota pickup sr5 cluster swap
  247. AFM - I did it - Made the adjustment.
  248. 22re thermostat housing bolts anti-seize?
  249. 22RE Running Hot
  250. I’m so happy my LSPV is ganked
