Parking break repair
Old Jul 24, 2021 | 02:54 PM
93&Me's Avatar
Hello all, my new to me 93 SR5 Pickup was having the ole blinking brake light problem. I believe it is a combination of the brake fluid needing a top off (as it blinks on deceleration) and some minor damage to the front parking break cable nearest the handle stops the handle from closing all the way because of the slight fraying. Rather than spend the now $125 for OEM new cable (197,500 miles and 98%, except the camper shell, has been serviced with OEM parts), do you think it would be possible to cut the cable shorter past the fray (not even 2") and re crimp the pin that attaches to the rod inside the brake lever assembly? then just adjust the torsion under the truck for correct operation.
I guess it really depends on how the pin is affixed to the cable, Does anyone have any ideas?
Old Jul 24, 2021 | 03:53 PM
wallytoo's Avatar
not a good chance that cutting 2" off the cable will render it useable. also, would you be able to trust that the crimp you added would hold?
Old Jul 25, 2021 | 12:00 AM
moto809's Avatar
5 Year Member
Not a chance at all, that brake cable is a very specific part. (Trust me, I tried.)
If you don't care about having a parking brake, you can unplug the switch at the base under the dash. That will turn the light off.
Old Jul 25, 2021 | 04:21 AM
wyoming9's Avatar
Red face
It comes down to having the tooling to crimp the cable once you shorten the cable you might need to add more length to the rear of the cable.
For all the work you need to be doing removing the cable crimping a new pin on adding a length to the rear .
At least find a used cable to modify myself I would buy a New Cable.
Remember the use of the Parking brake keeps the rear shoes adjusted it is a pain to adjust them every few weeks depending on brake use.
Old Jul 25, 2021 | 07:07 AM
br549arkie's Avatar
Rock Auto has Raybestos and AC Delco front brake cables for around 20 bucks. Drawback being they are not OEM and they are both made in china now.
Old Jul 25, 2021 | 12:42 PM
moto809's Avatar
5 Year Member
Just buy a new one. You'll be happy you did.
I already went through all the trouble of trying to repair my OEM cable back when they were a dealer only part at about $120.
I fought it and fought it and fought it and ultimately wound up driving my truck for 10 years without a parking brake.
Old Jul 26, 2021 | 07:08 PM
93&Me's Avatar
Thanks guys, bought one on rock auto
Matthews210
Nov 4, 2015 12:49 PM
Deus Ocelot
Feb 21, 2013 09:34 AM
Seacoast
Nov 29, 2008 12:04 PM
Etype R
Nov 14, 2005 06:37 AM
GaryBee
Sep 11, 2005 12:07 PM
