3.0 VZE, what is this vacuum line?
Old Jul 27, 2021 | 01:44 PM
Snypr18's Avatar
Hi everyone, while checking coolant the other day I noticed that this vacuum line appears to have been deliberately unplugged and tucked away over the radiator. I hesitate to just hook it back up in case it was removed for a reason, can anyone identify it?
Old Jul 27, 2021 | 06:25 PM
scope103's Avatar
I believe that's unmetered air (not vacuum) for the PAIR valve. http://web.archive.org/web/201311071...78pulsedse.pdf
The other possibility (my drawings aren't specific enough) is that it is metered air for the A/C and PS idle-ups, but I'm pretty sure it's for the PAIR.
Why? The PAIR has four screws, and with vehicles of your vintage they might get loose. This produces a buzzing noise. Tightening those screws (or replacing a few if they fell out) will stop the noise. Or, you can just go caveman style and pull the hose.
Old Jul 27, 2021 | 10:31 PM
Snypr18's Avatar
You know, its interesting you mention the A/C, as the truck runs great except when the A/C is running at idle. I wonder if this might be the cause. Guess I will have to hook it back up and see if it explodes.
Old Jul 28, 2021 | 05:56 AM
scope103's Avatar
If it's metered air (for the idle-ups), the fact that it's disconnected means a big "vacuum leak." For whatever reason it was disconnected in the first place, someone might have adjusted something to overcome the leak. Meaning: don't be too surprised if hooking up that line causes you to run "rich." At least until you find the underlying reason for it in the first place.
Old Jul 28, 2021 | 05:13 PM
1stgen88t4r's Avatar
That's a nice and shiny alternator. Did you install it or someone else?
Old Jul 29, 2021 | 09:12 PM
Snypr18's Avatar
Alternator was installed by a previous owner, not sure what brand, but it does have a refurb badge on it.
Old Jul 30, 2021 | 03:24 AM
I only ask because you need those hoses out of the way when you remove or install the alternator. Who ever did it probably forgot to re-attach it. Did it solve your AC problem?
Old Aug 3, 2021 | 09:49 PM
Snypr18's Avatar
Weather has been so nice here I have been riding the bike instead of taking the 4Runner. Hooked the vacuum line back up today, it does indeed seem to have fixed the weird idle with A/C on. Also looks like it may have fixed an issue where the truck has a super rough idle after being run, sitting for a bit, and then starting again. Will keep an eye on it.
Tbarba
Aug 6, 2017 04:08 PM
94RUNNER_SC
Feb 22, 2007 11:15 AM
SCdudeBro
Sep 21, 2006 05:44 PM
Victor
Oct 20, 2003 08:20 PM
Churnd
Apr 23, 2003 07:08 PM
