Replaced MAF and now Engine wont start
Old Oct 12, 2021 | 10:28 AM
stdreher's Avatar
Hello all. I went off of a reccomendation to clean the MAF and ended up damaging it. I ordered a new one (chinese made) and installed it and the engine will crank but still not start over. Does anybody have any advice as to what the issue might be? Its a 22re. Ive disconnected the battery in an attempt to reset it. Theres no blown fuses. The car was running and started up promptly before i damaged the maf.. I could use some help
Old Oct 12, 2021 | 10:52 AM
Robert m's Avatar
Not sure who recommended to clean the AFM on a 22re but there is nothing to really clean inside it.
Does it try to start at all or just crank? Do you have everything reconnected and intake hoses attached? Everything plugged in?
Old Oct 12, 2021 | 02:59 PM
scope103's Avatar
Don't tell me, lemme guess:
Welcome to YotaTech. There's a pretty good chance you've messed up the FC (fuel control) circuit, and the fuel pump is not running. Fortunately, it the easiest thing on your whole truck to diagnose. Jumper FP to B+ in your diagnostic connector. With key-on, you should hear the pump running. If your truck starts now, you've found (one of) the problems. Since your truck doesn't start-and-die in a few seconds, you probably have an open in the STArt circuit of the ignition switch as well.
Just so you know, you don't have an MAF (Mass Air Flow) sensor, Chinese or otherwise. You (should) have a VAF (Volume Air Flow) sensor. Different technology.
airkewld4life
Dec 27, 2009 06:09 AM
aron075
May 2, 2008 02:57 PM
HaveBlue
27
Oct 20, 2006 06:57 AM
cobrahunter
Aug 8, 2004 05:42 AM
DavidO06
May 23, 2003 03:17 PM
