H4 headlamp housing conversion
Old Jul 23, 2021 | 11:13 AM
keycw's Avatar
5 Year Member
after a few years of debating on the headlamp options, i decided to go with the fairly common H4 headlamp housing/bulb swap. few reasons. i think led's look ghetto, i think HIDs look even more ghetto. i am picky about tasteful mods to my build but i see the benefit in the H4 brightness over the conventional sealed beams that came stock. i ordered a set of the visionX housing and a set of their white bulbs. total cost about 100 bucks. i decided to do this job now because i was pulling my ARB bumper off for some winch work (clocking the ends a little) and it would be a perfect opportunity to get into the grill area. i stocked up some OEM parts, which i will provide for you. the job is very straight forward. i decided to also upgrade the headlamp harness with the H4 jumper harness that is also pretty common. ordered mien from lowrange offroad. it plugs into one of the original headlamp sockets, and has its own dedicated power from your alternator with some relays. no need to worry about burning up the undersized wiring now.
after i pluged in the new harness i pulled my bumper and grill. i cleaned up my headlamp buckets (NLA from toyota) and reinstalled them with new retention springs and adjuster nuts/bolts . P/N provided below. installed the housings and new retainer rings and screws (P/N below), tested the lighting to make sure it works and then reinstalled the grill with new clips and screws/grommets, P/N below. after install i adjusted the lamps at about 25 feet out and theyre amazingly brighter than sealed beams. right now the only thing im battling is that the high beam indicator light is dim. will dig into that later.
bumper removal made easy with engine hoist
winch to be clocked on both ends
naked
grill clips
retainer ring screws (8)
screws and grommets
retainer rings
springs
little plastic grommets for behind the buckets
new housings and bulbs
adjusters
back together
Old Jul 25, 2021 | 05:23 AM
wallytoo's Avatar
for your highbeam indicator, i bet you can install an LED in place of the original bulb and get it to be bright. i did so with mine after replacing the original headlight harness with an h4 harness (keeping the sealed beam headlamps), which caused a dim indicator.
details from my t4r thread
Old Jul 25, 2021 | 08:25 AM
keycw's Avatar
5 Year Member
good idea Wally thanks! Will look into that soon. Thanks for the link too.
Old Jul 25, 2021 | 09:00 AM
itscrazytom's Avatar
Thanks for the write up and parts info, much appreciated. I've been chasing those clips for two years and ended up using zip ties.
Old Jul 25, 2021 | 09:42 AM
Melrose 4r's Avatar
5 Year Member
Great write up, Cody.
on the rare occasions when i use my high beams, i find the brightness of the blue indicator excessive, to the point that i want to put a piece of tape over it.
Old Jul 25, 2021 | 09:47 AM
keycw's Avatar
5 Year Member
i actually agree with this haha. right now, when i engage the highbeams it doesnt turn on immediately, it kind of slowly turns on like a reverse dimming feature. when its on all the way it is very dim though. i think it similar to what wally talked about earlier with low voltage because the harness only plugs into one side of the oem harness.
Old Jul 25, 2021 | 09:55 AM
keycw's Avatar
5 Year Member
here are some photos of low and high beams with the new setup for anyone interested. if you know how dim and useless the old sealed beams are then you will appreciate how bright these H4s are!
low beams
high beams
pdyebrasil
12
Nov 24, 2014 06:29 PM
93YotaGuy
Jan 19, 2012 08:32 AM
elblako91
29
Dec 16, 2010 10:16 AM
RiCh_90-yota
18
Oct 3, 2008 07:27 PM
Keggo
May 30, 2007 11:15 AM
