3rd gen running problems
Old Sep 16, 2021 | 07:46 PM
Vadnais's Avatar
Hey i have 89 Toyota pickup I parked it 5years ago when it ran it has the 3.0 v6, recently I've been trying to get it running again not sure what is causing it to not run now after its been sitting for so long and I don't want to replace a bunch of stuff to find the problem if anyone has an idea let me know!
Old Sep 16, 2021 | 07:48 PM
millball's Avatar
Look to fouled fuel pump and injectors
Old Sep 17, 2021 | 09:49 AM
Vadnais's Avatar
yeah I was thinking it could be a bad fuel pump do they usually go bad after sitting for awhile?
Old Sep 17, 2021 | 10:17 AM
millball's Avatar
It's not a matter of the pump going bad.
It's the corrosive goo that gas turns into when it sits for years.
Old Sep 17, 2021 | 10:43 AM
Vadnais's Avatar
Oh okay that would make sense i think it had almost full tank when I parked it I’ll replace the pump they aren’t that expensive
Old Sep 17, 2021 | 10:50 AM
scope103's Avatar
Originally Posted by Vadnais
... I’ll replace the pump they aren’t that expensive
Lots of parts "aren't that expensive." Until you start replacing a bunch of them.
Testing that pump is dead-simple. Remove the fuel return line from the FPR, replace with a line to a suitable container. Start the fuel pump with the diagnostic connector. I get about 1/2 liter/min that way. If you get nothing out, can you hear the pump running? If the pump is running, it's probably still pumping, and you've got a blockage somewhere from the pump to the FPR.
Or, just replace the pump, and then come back here to ask "uh, now what?"
millball's Avatar
Don't just start replacing stuff.
Perform tests to determine what's wrong.
Plenty threads oh here about what to do and how to do it.
Lotsa cheap fuel pumps, for sure. Most are junk. Look for a Denso, if it turns out you actually need one.
Old Oct 4, 2021 | 10:13 AM
Vadnais's Avatar
Found the issue the EFI fuse keeps blowing every time I try to start it I am gonna start looking around for wires that need to be replaced not sure where to start tho?
Old Oct 4, 2021 | 03:54 PM
scope103's Avatar
Well, it can be almost anything. But what seems to be common is having shorted wires to the O2 sensor. I'd start there.
Good Times
24
May 21, 2010 08:23 AM
xcmountain80
26
Jul 8, 2009 09:13 AM
FilthyRich
Jul 2, 2005 06:51 PM
RawRunner
10
Oct 4, 2004 05:37 PM
PhxTRDRunner
Apr 6, 2003 04:00 PM
