- 3VZE motor overheated...random knocking?
- 1987 TOYOTA Pickup Odometer Correction
- Strange 3vze knock Diag
- Anyone know what this is?
- Toyota FIPG black on transmission components?
- What is this? i made a whoops
- Air shocks in front?
- Distributor issue
- Pulling the radiator... anything I should know?
- 1995 4runner issue
- Fixing the Instrument Cluster
- 90 v6 yota pickup missfire runs rich
- Help 92 22RE won't start
- Trail gear bumper hitch?
- Extra Pink Wire in Instrument Cluster Connector
- Heater issues any advice greatly appreciated
- 1987 4Runner rear sag question on OME leafs
- gear problem?
- '89 DLX 4x4 Alternator and Warning lights?
- trail gears rear drive shaft disconnect
- V6 Caliper Anti-Rattle Clips / Springs
- Audi a4 engine swap
- Black electrical plug under RF fender??
- Aftermarket seats
- Unique 3.0 starting issue
- 3.0 slight intermittant miss
- name this part (connect to idler arm)
- Tapped in rear main seal too far.....
- power steering troubles
- 3VZE - Cleaning Plenum and Intake Manifold
- 87 4runner power locks not working
- leveling kit for a 90 pickup
- 1987 Pickup Cherokee Coil Spring
- elocker pinion
- Distributor problem after wreck, 95 SR5 V6 4runner
- gearing the 3 slow
- 3vze power steering pump pulley removal
- my ticket inducing top speed
- Which camshaft should I go with?
- first gen taco door panel pockets 93 pickup door panel... anyone done it?
- im stupid.. help me understand this swap info
- 15" 235 /29" pizza cutters for MPG on road only
- 87hoerunner's 87 4Runner Build Thread
- Cracked door hinge -- repairable?
- Sound-Proofing/Deadening & Interior Work
- high idle with battery light illuminated
- passenger-side cam sel leak (persistent)
- Suggestions for a Cold Air Intake, 2nd Gen 4Runner
- 3rd gen > 2nd gen bumpers
- Uhhhh major brain malfunction
- 3vze Ignition Timing Short Problems / Any Suggestions?
- Electrical problems 1988 22RE 4x4 truck, need help
- 89 4x4 pickup transmission problems
- Speedometer acting up then quit.
- Bad gas mileage <-- please read
- Replacement fuel tank
- 1st Gen 4Runner Tailgate Latch Cable Repair and Upgrade
- Aisin Hub Part Numbers
- 93 runner power steering leak from hell
- Automatic Transmission ( 1 Ton Truck ) Question
- Ball Joint spacers
- 22re new motor no power
- '90 22RE EFI pickup fuel pump not turning on
- Blue interior what color console?
- Needed a Ford :facepalm:
- 22RE timing cover bolts help
- 5-speed popping out of 1st not seat/bushings
- Master Cylinder Part Question (pic)
- Newbie's first Toyota truck
- 95 Tacoma 2.7L 4cyl has intermittent miss
- 94 clutch problem
- truck wont start trying to pin point why. please help.
- ISR Mod on 3VZ-E?
- Losing 3 quarts of water in 90' 3.0, where to begin?
- Improper Coolant Reservoir connections?
- Power Valve Diaphragm- potential source of stalling?
- Pinpointing tanny/transfer case leaks
- Leak around front housing where housing and motor attach
- Parts Fiche
- 22r whining noise, then oil light came on and truck shut off
- Tires for on road only best gas milage and towing
- bumper replacement guidelines
- 22-RE Starting Problem
- Quick question on replacing brake booster
- motor swap
- Bolts that connect exhaust manifold to rest of the exhaust
- How do I Measure the length for a cv rear driveshaft??
- 1995 Toyota 4Runner 4x4 SR5
- Things to look for when buying a 90-95 truck
- t p s.
- stupid CEL only when cold
- tps unplugged and no ck engn light??
- 1989 Toyota 2WD 22r - minor issues
- Codes 14, 42 and 43?
- V6 Caliper Conversion Questions
- 5 spd G54 stuck in reverse!
- Tightening 3.0 3vze crankshaft bolt
- Weird Jolt While Driving - Puzzled
- A340E Transmission Questions
- Inclinemeter..questions
- Squeal!!
- Weird cooling behavior
- Hesitation When Starting Truck
- 2 4Runner 1 dude
- rough countty aal
- interior dome light prob 88 pickup
- 1990 4Runner Radio Mounting Brackets Help
- New TOY...ota
- low oil pressure..should i be worried?
- inconsistent idle 22re
- 3.0 needs Love
- 1986 4WD fuel tank problems
- Fuel pump pressure???
- Pretty happy with compression test on 3vze
- gauge cluster swap
- Inexpensive eBay steering kit opinions
- 2wd vs 4x4 bumpers, difference?
- Bracket Pic Request
- replacement fenders and hood
- Bed sides to weak to mount tire carrier?
- Warn/Arb style winch bumper w body lift?
- power window harness?
- Rear window regulator arm "slider" jimmy rig help
- This is, I think, going to be a running thread
- 91 3.0l Oil and Coolant leak
- Wow, my 3.0 has personality now !
- Where does this ground strap attach? (pics)
- Brake overhaul questions
- 1988 Toyota SR5
- 1988 4runner rear axle swap to axle with elocker
- 86 yota, 2003 4.3 conversion wiring harness
- Are 3.0's really that bad?
- Transmission Questions
- Speedometer and temp gauge broken :(
- Rear tailgate problem! lock stuck!
- Loss of power, LOUD clicking, blown head gasket
- timing problems
- Rewiring 5 harness to a 4 wire harness 1989
- tire air pressure? post yours!
- used front 7.5 ifs 3rd w/ arb
- Very curious 4WD problem! HELP!
- Clutch fork floating??
- HVAC control sliders
- 1994 pick-up rebuild
- 92 1 Ton Truck Conversion 2wd to 4wd
- running issues
- 1994 4Runner 3.0 Power Issue
- What is this extra steering strut for and is it necessary?
- Best way to lift a lifted truck to work on it
- weird idle issue after coolant flush
- Killer Toy Tops is back, and I gots me one.
- 22re performance build questions
- Engine Rebuild
- how do i tell EXACTLY what engine is in my truck
- Considering buying a 95 2wd runner. Have some questions.
- 4runner 3vze problem
- Radiator overheating & warning lights on
- Dark smoke coming out of air cleaner hose
- Fuel line part number 22re
- Anybody run Gabriel Max Control shocks?
- Clutch actuated pedal switch??
- rpm change when brakes a pushed.
- 22re/rec... same blocks and heads?
- 1988 4runner license plate lights
- 3vze engine decrapping(cleaning)
- Spark Plugs issue
- HG Problem/Question
- CV Shaft, Brake Pads and Rotors, and Steering Stabilizer Install Advice
- new head on 88 22re pickup
- Exhaust Upgrade
- 87 22r: Bad casting on Aisin Water Pump WPT007 from RockAuto
- how easy are 22re/22r heads to crack or warp?
- Hi, and please help with bubbling overflow
- radio swap need some help
- The dreaded Rear Window
- Rear end angle?
- 93 4runner full maintenance
- coolant problem
- 1st Gen Replacement Windshield
- New guy need HELP!!!!
- 3.0 Rear Main Seal?
- 22rp - alternator relocated to the passenger side
- Clutch banging while disengaging..?
- 22re torque specs
- 3.0 throttle body thermo valve... fail!
- 3VZ-E Transmission Questions
- wiper arm part
- 88 4runner having fuel system issues...PLEASE HELP!!!
- Front diff drive flange seal
- Bad Gas Milage, CEL Code 3VZ-E
- 3.slow need help identifying these
- Sensatrac or Rancho 5000?
- 3VZE -TPS Adjustment
- help with gasket
- lowering a 94 4wd.
- just wondering...
- 94 3.0 stalls when come to a stop??
- It's my turn for a stupid LC rear coil question, difference between front and rear?
- 3vze HELP PLEASE
- 94 4runner auto trans doesnt like to go in gear
- cylinders 5 and 6 are dead
- 92 toyota center support bearing free play
- 86 2wd overheated on the hwy
- What are the chances this will kill me?
- major issue with 93 4runner 3.0
- Pitman Arm Joint Hitting Inner Tie Rod End
- help running rough CEL 25,26
- Bringing an 88 R22RE back from 5 years of Non-Op
- New ARB Bumper & some other shots
- Transmission Slipping When Hot -- Need Help Diagnosing
- alternator brushes
- Motor dies when i push the braked! Any advise?
- Gearing and gas mileage on a built 4runner
- anyone have an experience with the newer chevy 2 +1 OL leaf springs?
- 2 door 4runner general information
- Back finally with another Yota
- Need pics of Fisher plow mounts 86-95!
- Thermostat flange size difference
- screw part on intake
- What is the most weight you've hauled in your Yota pickup?
- Power steering hoses..
- 22re Rough Idle, Walk Through This With Me?
- Ticking Noise or Rod Knocking Noise
- Oil pressure drops
- CEL Flashing Repeatedly when Pulling Codes
- FJC owner looking to add the to Yota Fam
- Rear Sag: FJ Cruiser Springs on 4Runner 2nd Gen? Alternative compatible coils?
- I have a massive power steering leak...
- Loud ticking on startup 3VZE
- Just a friendly battery heads up!
- Oil fluctuation?
- Spare washer after working on front axle?
- High Idle, Then Dies
- 22re rebuild tips
- 1994 4Runner fuel door problems
- Dying after 10+ minutes
- First Post, what to look for?
- Clutch replacement
- PLEase help 1990 truck 22re power loss please help
- Phone Mounting
- Brake lines, '87 4runner Turbo, Pro-Comp
- A/C Tensioner Pulley 89 4Runner 22RE
- Drivetrain Lift Question
- left brake drum and backplate soaking in gear oil
- Identify these grommets please
- Wont Warm Start
- Solved: 4Runner 3VZE A/C idle dropped
- Help, 1986 4runner rear window switch replacements
- Loping cold idle below 50f
